08-09-2016, 11:01 PM | #1 |
It's all hers.
Drives: 2015 ZL1 Join Date: Jan 2012
Mods & injectors
I'm on the learning curve with the ZL1. At what point in mod progression is it required to upgrade the injectors? Headers and CAI with a tune are on the short list but at what point when changing pulley(s) and porting the TB & snout are injectors needed, what is a "safe" happy medium?
08-10-2016, 12:02 AM | #2 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
Anything over 10% overdrive I believe, if you're doing blower porting then just swap injectors while the blower is off. Piece of mind and easy to do with blower off
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
08-10-2016, 12:44 AM | #3 |
"BEASTM*DE"
Check out some of the vendors on this site...They usually have several upgrade packages to choose from and each package tells you what parts make it up based on your desired HP gain...They go from Stage 1 to damn near unlimited...
08-10-2016, 12:46 AM | #4 |
Drives: Zl1 Join Date: May 2016
I had only cat deletes, cai and a 2.4 upper with 85lb injectors and my stock pump couldn't keep up without a BAP. I know lots of guys say you can run a decent size pulley without Injectors or any fuel upgrades....but keep in mind all cars are different. My tuner and I were both shocked when my fuel pressure dropped to 37psi with what id consider "minimal" mods.
08-10-2016, 01:16 AM | #5 |
It's all hers.
It all seems fair enough, LT headers and CAI are a safe place but when I jump to TB & snout work & a pulley then injectors and BAP are required.
08-10-2016, 08:11 AM | #6 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
CAI and headers would probably be OK. But when you start swapping pulleys you're going to need injectors. For instance, a 9.55" lower pulley and nothing else pushed my stock injectors to 130% duty cycle. For reference, most tuners would like max duty cycle to be 85%. So even the stock ZL1 is pushing past that.
Bryan 2018 ZL1 M6
08-10-2016, 10:37 AM | #7 |
Drives: CTS-V Join Date: Dec 2013
no BAP is required only injectors
08-10-2016, 03:25 PM | #8 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
ZO6 Bryan is spot on. I maxed out the stock injectors with just a Roto-Fab CAI, Big Gulp and 10% lower pulley.
Anytime you up the boost, the fuel system is likely going to need an upgrade as well.
08-10-2016, 03:55 PM | #9 | |
Drives: Fast Join Date: Mar 2015
Can't tell you how much these injectors are a damn bottleneck on this car. |
08-10-2016, 05:53 PM | #10 |
If you get up around 12-13 lbs of boost you will need a BAP also.
Bryan 2018 ZL1 M6
08-10-2016, 06:12 PM | #11 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Doing E85, Flex Fuel Sensor, 1300 IDs, and Fore or Squash system soon ... Problems solved
08-10-2016, 06:15 PM | #12 |
1300s? Dayum.
08-10-2016, 10:01 PM | #13 |
It's all hers.
Some good info to chew on guys, thank you!! I'm mowing over the options and how far I want to take things.
08-11-2016, 01:21 AM | #14 |
