View our official forum sponsors list. |
Thread Tools |
05-07-2012, 02:13 PM | #1 |
Drives: 2016 1SS Join Date: Apr 2012
Phastek X5 Cold Air Intake for MagnaCharger TVS2300
Phastek X5 Cold Air Intake for MagnaCharger TVS2300 :: 2010-2012 Camaro SS
2010, 2011, 2012 Camaro SS Phastek Performance X5 Cold Air Intake for Camaros with Magnuson Magnacharger TVS 2300 by Roto-Fab #10161012 This unit 2010-2011 Camaros with the Magnacharger Superchargers or Whipple Superchargers installed Roto-Fab's 2010 Camaro Cold Air Intake/Induction (CAI) for your V8 equipped Camaro SS! (LS3 & L99 Engines) *Air Box custom made to keep engine/radiator heat away from your filter. *Molded air box adapter tube incorporates the MAF (mass air flow) sensor. *Large 6" filter mounting flange. *Inlet elbow available in cross link poly (plastic), polished or painted stainless steel. *High quality silicone hoses available in a variety of colors. *Air Box available in a variety of colors. *Installs easily using factory mounting points. *Doesn't set any codes/ no tuning required. *Oil or dry filter available. This system has all of the great performance and appearance features of our standard Camaro CAI, along with a custom molded oversized tube for your S/C upgrade. Just because some intakes will "clamp up" to the Maggie system, that doesn't mean they meet the flow requirements to maximize the power gains of this modification. The Roto-fab CAI is the preferred system for many tuners because of superior performance and great tuning capabilities. With this kit you receive our oversized plastic tube which is molded to step up and align properly to the new throttle body location. We also include a custom transition hump hose for coupling the larger air tube to the throttle body. A longer breather hose and fitting are supplied as well. Installation is simple with detailed instructions and absolutely no modifications to your car. This is the complete CAI intake system which includes everything necessary to replace your stock air intake system. If you already have the Roto-fab CAI system on your Camaro, you can simpy purchase our Magnuson upgrade kit. Note: while our dry filter performs great for N/A applications, we recommend our oil filter for use with your S/C. Our powder coat finish is durable and provides a close color match however varies slightly from run to run. Also the surface isn’t quite as smooth as our automotive finish. Please allow a 1-2 week lead time for automotive painted finishes. Order today at www.PhastekPerformance.com |
05-14-2012, 01:35 PM | #2 |
Taking orders
05-31-2012, 08:58 AM | #3 |
post or pm if you have questions
06-12-2012, 11:34 AM | #4 |
post or pm with questions
06-18-2012, 02:50 PM | #5 |
HI !
06-26-2012, 04:18 PM | #6 |
taking orders
07-10-2012, 10:07 AM | #7 |
Place your orders
