Old 08-23-2014, 12:33 PM   #1
6bloodychunks
6bloodychunks's Avatar
Drives: 2011 2SS/RS SGM
is my brake shop crazy? they told me they need a special tool to change rear pads.
went to my brake shop to get rear pads replaced,
dropped the car off and gave them a few hours and went back to pick it up.
they told me they couldnt change them,
because they need a special tool to change the rear pads,
and that they do not have it.
are they serious? or just mis-informed on this brake system?
any help is greatly appreciated
---2011 synergy green 2SS/RS---
09/27/2010 - (3800)
10/01/2010 - (4200)
10/09/2010 - (4800) Vehicle on final destination route
10/19/2010 - (5000) delivered to dealer
11/19/2010 - (6000) delivered to customer
6bloodychunks is offline   Reply With Quote
Old 08-23-2014, 12:35 PM   #2
Synner
Drives: cars
They need hands.
They need a punch/nail/screwdriver to knock the pins out.
Done.
They are morons.
Old 08-23-2014, 12:38 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Originally Posted by Synner View Post
They need hands.
Done.
They are morons.
Agreed
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 08-23-2014, 12:43 PM   #4
6bloodychunks
my suspicions were correct then LOL
thanks
guess ill just use them for exhaust,
they did a sweet job on any exhaust related things ive went there for.
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 08-23-2014, 12:44 PM   #5
cabbe
Drives: 2014 2ss 1le
I have a 2011 2ss as well. I changed them my self in 30 minutes. Nothing special needed.
cabbe is offline   Reply With Quote
Old 08-23-2014, 12:53 PM   #6
6bloodychunks
was just going to let them do it for convenience,
but ive done the brakes on all my cars before this one,
so i will just get on it LOL
you should have seen my face when they said "special tool"
i was thinking "yeah ,youre a special tool alright" LOL
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 08-23-2014, 10:55 PM   #7
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
I wouldn't let them do exhaust work if they couldn't figure out how to take out a couple simple pins on your brakes
TommyTheCat is offline   Reply With Quote
Old 08-24-2014, 12:20 AM   #8
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Run, run away and never go back. They are idiots.
CHMSC is offline   Reply With Quote
Old 08-24-2014, 01:45 AM   #9
mpiersd
mpiersd's Avatar
Drives: ABM #2041
Exactly. If they can't figure out brake pads, do you REALLY want to trust them with a welder under your car?
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903
ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me
Cortana: 2015 Harley Davidson Road Glide Special
V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen
Own an Aqua Blue Metallic Camaro?
Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros!
mpiersd is offline   Reply With Quote
Old 08-24-2014, 08:06 AM   #10
L99CAMA2011
L99CAMA2011's Avatar
They were right , there is a special tool called a brain, appears they didn't have one on hand.
Old 08-24-2014, 10:52 AM   #11
bonesrn27
Drives: 2010 Camaro SS
haven't done brakes on my ss,but some gm's do require a simple tool that pushes the piston back into the caliper,not sure on yours.. u can get em at autozone for free...still I would also avoid that shop like the plague,loi
bonesrn27 is offline   Reply With Quote
Old 08-24-2014, 11:21 AM   #12
Synner
Drives: cars
I know plenty of mechanics that can't weld and plenty of welders that aren't mechanics. Doesn't mean they're bad at their day job.
Old 08-24-2014, 11:28 AM   #13
Synner
Drives: cars
There's many options that don't require anything or maybe a universal tool.
1) Most times they push right back in with finger pressure.
2) Possibly crack the bleeder and then push in if it's being annoying, since they should be bleeding them anyways...
3) I have a welders clamp that will fit in any caliper I've ever done brakes on, $8 at any home improvement place, and a piece of scrap metal or old brake pad backing plate to distribute pressure. I only use this on the old/crusty/rusty ones or if the new pad is massively thick and needs 100% clearance to get it back in.
4) Some people will use a crow bar for leverage but personally I think thats a bad idea unless the rotors are being replaced as well. Lateral loading something prone to warping that far out from its mounting point is never a good idea.
Old 08-24-2014, 08:52 PM   #14
DP Valentino
DP Valentino's Avatar
Drives: 2010 CGM Chevrolet Camaro LS
They need hands.
Done.
They are morons.
2010 Chevrolet Camaro CGM LS - Performance Mods: "Everything I can get bolt-on wise to make it run good!"
Exterior Mods: "Everything I can get to make it look good!"
Interior Mods: "Everything I can get to make it look good!"
DP Valentino is offline   Reply With Quote
