Old 10-01-2017, 02:29 PM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
e85 or m1?
after running into snags with cage building and losing pretty much all the stock wiring and the factory gas tank... my car will pretty much be a dragood car that see very, very minimal street driving(if at all).
which brings me to my next thought of running m1 for fuel instead of e85. I'm really at a crossroad for this!!!
I have an 8 gallon fuel cell and will be running a prostar 750 pump. if I go with ma1 I will add a second pump or go belt drive.
I already have the fuel cell, Bosch 210lb injectors(rated at 43.5) and pre existing teflon 8an feed/ return lines. so going with meth I will need to run a bigger feed/return and a set of Moran 500lb injectors which are about 2500 a set.
what are the thoughts on this? looking to make some mid 8 second passes!
ttshovel is offline   Reply With Quote
Old 10-01-2017, 03:00 PM   #2
Bo White
Bo White's Avatar
Alot of my fiends just buy M1 and mix their own E85
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 10-01-2017, 05:00 PM   #3
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Hmmm, think I would stick with the ethanol but go with E98 for insurance.
What does your tuner say?
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 10-01-2017, 05:21 PM   #4
ttshovel
ttshovel's Avatar
don't know. it's whatever I decide at the end of the day...
a pro would be I wouldn't need an intercooler, saving weight and fab costs, the con would be I really wouldn't be able to drive anywhere on the street without having a bigger cell.
I'll talk with the guy doing the fab works and see what he thinks as he hasn't started the turbo kit fabbing yet...
Old 10-01-2017, 06:43 PM   #5
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Race car problems.
Unavowed is offline   Reply With Quote
Old 10-01-2017, 07:03 PM   #6
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Post on yellow bullet
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 10-01-2017, 08:15 PM   #7
ttshovel
ttshovel's Avatar
Originally Posted by Unavowed View Post
Race car problems.
exactly
Old 10-01-2017, 08:17 PM   #8
ttshovel
ttshovel's Avatar
I've been reading on there pretty much all day and everyone is all for the methanol lol
Old 11-01-2017, 02:46 AM   #9
Bo White
Bo White's Avatar
Let me expand on my M1 post. Methanol and ethanol are pretty different and dont tune the same.
Methanol is roughly 6.5:1 a/f
Ethanol is roughly 9:1 a/f
Totalled:
Old 11-01-2017, 03:20 PM   #10
ttshovel
ttshovel's Avatar
you're good man. I know stoich is different between the 2 fuels. the guy building the car shot me down at the idea of it. for my et/hp goals it's not needed
