10-29-2017, 06:49 PM | #1 |
Drives: 2010 ss Join Date: Oct 2015
how much boost
Ok I have a ecs Paxton on e85 and I see I am peaking 14 psi,on stock engine and headers,fore daul pumps,think dare go more boost or stop where I'm at,755rwhp631 torque
10-29-2017, 07:12 PM | #2 |
Drives: Z06 wannabe Join Date: Feb 2015
I am no expert here, but I am curious... I am on 11.5 lbs (peaks at 12 on the finish line) with an LSA stock bottom end (ARP head bolts and LS9 gaskets)
I had always heard 12 was a little pushy on stock pistons? *Shurg*
Apex Focused
10-29-2017, 08:02 PM | #3 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
I don't think a certain psi matters as much as the rwhp. I'm at 815 rwhp on a mustang dyno @ 16.5 psi. I have a turbo specific cam so it tends to allow more boost to build from what I've seen when compared an NA cam.
I think most would say 800 rwhp is relatively Ok with good tuning.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
10-29-2017, 11:20 PM | #4 | |
Drives: 2012 CTS-V, 2010 Camaro SS Join Date: Sep 2013
People can run 16 psi and make different whp numbers. I always went by on completely stock internals anything over 12 is starting to push it. Also depends how much WOT and what fuel/tune you use but I think 12 has been a pretty standard number through the years.
2012 CTS-V: Cosmetic Chute. |
10-30-2017, 07:08 AM | #5 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
I'd crank it up to 18/20 psi on that blower, centrificals are so progressive in the power band you'll be fine. It's all about where your peak hp hits is what causes bent rods. That's why root style and big nitrous shot motors take such a beating because the power is instant not progressively. Much how a big turbo stock 4.8 can do 30 psi on stock internals because it doesn't even make boost till 6k rpms in the power band.
10-30-2017, 08:38 AM | #6 | |
E-85 is very forgiving so you likely have more room. Depending on which blower you have you may be at the end of it's efficiency. You might need to step up the blower as well. Ted.
www.jannettyracing.com
10-30-2017, 12:30 PM | #7 | |
10-31-2017, 12:04 PM | #8 | |
Every build and car are different but dipping into double digit boost is always putting strain on stock internals. I have been running 10psi for 5 years on my SS and it has never given a problem.
11-01-2017, 05:53 PM | #9 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
I found out the hard way that 13.5lbs boost was my limit.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
11-01-2017, 06:16 PM | #10 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
I will be going for 900rwhp @ 16psi on stock bottom this Saturday... hopefully the clutch holds.
11-01-2017, 09:49 PM | #11 |
All about the tune! And some luck maybe!
