Old 11-01-2017, 04:19 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
Maggie 2300 making 90+ kpa at idle whats wrong?
Car is making positive pressure on start up and when it idles its 90+ kpa, 408 with btr pds blower stage 3 cam, ls3 ported heads. Tuner thinks it might be a air leak somewhere past snout plenum area to lower manifold on maggie
hou30guy is offline   Reply With Quote
Old 11-01-2017, 04:29 PM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Bypass valve malfunction?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 11-01-2017, 05:23 PM   #3
hou30guy
It didn't seem like it to me
Old 11-09-2017, 12:23 AM   #4
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Is the map calibrated correctly? I know when I switched from the stock map to the zl1 map It was reading boost at idle.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 11-09-2017, 04:01 AM   #5
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
X2 to check bypass valve movement once checked out I would move on to vacume leak.
Pro-tuned is offline   Reply With Quote
Old 11-09-2017, 08:09 AM   #6
hou30guy
Map settings is correct as i did it myself with right specs, i can see the bypass moving back and forth til it idles out normal so its moving as should but i contacted magnuson supercharger and they told me to try certain things with the bypass valve and then email them back if thats fine, literally waiting to get off this cruise ship as i was gone 5 days so i will try that and if not then a vacuum leak somewhere
