11-11-2017, 07:55 PM | #1 |
Drives: 1992 LS3 Typhoon Join Date: Jul 2017
HP, Boost, and RPM ?
I am trying to figure out the best pulley option for my build and would like to tap into everyone’s knowledge and experience. I did a ton of research and built my engine to handle a lot of power and run 8k RPM. I have a Maggie TVS 2300 and am trying to understand if I will make more power with a large pulley and more RPM or a small pulley and less RPM. I will have an aggressive IC cooling system.
11-13-2017, 12:45 PM | #2 | |
What size engine do you have? How much power are you trying to make? What fuel will you be burning? What fuel system and injectors are you running?
www.jannettyracing.com
11-13-2017, 04:51 PM | #3 |
Yes, thank you. My last car was an Eaton 03 Cobra. Ran 10.59 in the 1/4 and my best results were high boost with lower RPM. This build is different and the TVS is much more effecient than the Eaton.
It is a new LS3 - TVS2300, LSA crank, Manley rods, Wiseco pistons, ported heads and intake, aftermarket valve train, etc.. I am going to run E85 with either ID1050’s or ID1300’s. My goal is 700-750 AWHP with good drivability. |
11-14-2017, 07:28 AM | #4 | |
It will take a 10 rib drive system, an Overdrive cog on the back, 102 TB, and a plenum spacer to move that much air then you have to deal with the very high IAT due to the very small intercooler inside the blower manifold which is a restriction in and of itself. We pushed the Maggie to 9.80s in a full weight 2SS camaro. With a built motor you would be better off moving to a larger blower like the Whipple 2.9. then 800+ will be easy.
11-14-2017, 09:37 AM | #5 | |
Sounds like aggressive pulley set up and lower RPM should be my plan. Down the road I may look into a larger blower or a small shot. I am curious if someone will introduce the TVS 2650 for the LS3. I am a fan of the (4) lobe rotors. |
11-15-2017, 07:40 PM | #6 |
Drives: 14' 2ss convertible Join Date: Oct 2017
You headed in the right direction. Your boost number will not be as high but you'll extend the blower rpm range. It's a boost psi vs. flow question. It's amazing that you'll have a 8k motor on the street.
If the blower itself was large for the application this would work out well and keep the motor out of surge down low. So with that said it will depend on how much your blower has in reserve. I see you have good rods if forged but when moving the rpm range to 8k then the stress is more squarely placed on caps and bolts. Bolt upgrades are mandatory. I think you have but didn't see any reference . |
11-16-2017, 08:27 AM | #7 | |
Whipple also has a new generation of blower hitting the market soon.
11-17-2017, 11:26 AM | #8 |
