03-13-2018, 05:25 PM | #1 |
Drives: 2012 Camaro 2SS/RS M6 Join Date: Feb 2016
Exhaust too loud for track?
I have already paid to go to Track Night in America at Lime Rock park in CT. The I found out that there is a sound rule. Your car has to be under 86db at 50 feet away. I have long tube headers, high flow cats and solo performance mach X catback. Do you think I will have a problem?
If so, any ideas on the best easy way to quiet it down enough? |
03-13-2018, 11:12 PM | #2 |
Drives: 2014 Camaro SS L99 Join Date: Dec 2016
I would say yes.. if I had to guess most camaro’s with aftermarket exhausts at 50ft away would be about 90-100db?I know a lawn mower from 100ft away is around 65-70db
03-14-2018, 05:51 AM | #3 |
Started#gottalovethatblue
Yep, you're probably screwed. I have Solo's Mach XL catback with long tubes and cats which has minimally more muffling than their Mach X. If you're only idling you'll probably be fine, but if there's much or any throttle you're done for.
03-17-2018, 08:22 AM | #4 |
Yeah. I figured it wouldnt be good. I emailed the them to see if I could get a refund for the track event and bought a cheap db meter on Amazon. I will keep you posted on how loud it is.
03-17-2018, 11:57 AM | #5 |
SS
exhaust tip turn downs an option?
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
03-17-2018, 03:40 PM | #6 |
03-17-2018, 10:10 PM | #7 |
SS
not sure just thinking i will need to address the same issues
03-18-2018, 09:42 AM | #8 |
old school chevy rodder
It about when....when at idle or when at WOT screaming down the track.....
03-18-2018, 09:55 AM | #9 |
Drives: 14 and 15 SS's Join Date: Feb 2018
Do they officially test it?
If so, what are the parameters of the test? |
03-18-2018, 11:12 AM | #10 |
I haven't been there yet but, from what I have read, believe there is someone in a booth 50 feet from the track measuring the db. If its over 86 your flagged.
03-18-2018, 11:14 AM | #11 |
03-18-2018, 05:23 PM | #12 |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
If you can't get your money back
Just lift when you go past the sound meter.
03-18-2018, 07:54 PM | #13 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Wouldn't do me any good to go there. I have long tube headers high flow cats CAI different TB Dyno tune. Plus I run with my QTP cutouts open.
03-18-2018, 09:55 PM | #14 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Not an option. I deal with this out west, and they will flag you if you lift at the sound station.....
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
