04-03-2021, 09:31 AM | #1 |
Drives: 2010 Camaro SS Join Date: Oct 2020
VVT CAM install
Just got done installing VVT2 Cam by GPI. It has a little wiggle room. It moves horizontal about 1/4 of an inch. Is that normal? I had to pull it forward to get the phase r bolted up to it.
https://photos.app.goo.gl/Vt2QYbEpGaESaMsG8 Sent from my SM-F916U using Tapatalk |
04-03-2021, 10:08 AM | #2 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Yes that's normal
04-03-2021, 10:10 AM | #3 |
04-03-2021, 12:39 PM | #4 |
Drives: 15 Camaro SS Join Date: Oct 2018
Definitely normal and not 100% sure on the second question
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
04-04-2021, 10:06 AM | #5 |
That's my old plate. You can see it is definitely doing some rubbing. Seems like you would not want that.....but I guess GM knows what they are doing......
04-04-2021, 06:29 PM | #6 | |
I just swapped the camshaft on my L99 in August 2020... I already forgot how it looked in there exactly. Were you able to assemble the timing chain without dropping the oil pan? I tried and tried but ended up having to drop the pan and loosen the oil pump.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
04-04-2021, 06:30 PM | #7 |
Also be sure to put a new o ring on the pump if you drop the pan.
04-04-2021, 06:40 PM | #8 |
I had to drop mine also. After I spent 3 hours trying to find the double threaded stud bolt on the driver's side that hold the starter cable tray.
0 documentation on that little bastard!!! Ended up tieing some fishing string around it. Did you replace oil pan gasket? Sent from my SM-F916U using Tapatalk |
04-04-2021, 06:51 PM | #9 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
You didn't change the cam plate?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-05-2021, 01:04 AM | #10 |
Yes I definitely changed cam plate. The picture is my old cam plate. Just trying to understand why there is so much play on the cam, especially since it is clear it is rubbing against the cam plate. Just seems like a poor destination me....
