04-03-2021, 12:11 PM | #1 |
#teamGPI
Drives: 2010 Camaro SS Join Date: Aug 2020
Cold start, exhaust coming outta driver side more than passenger side
I was reading that with an x pipe which is what I have that this is normal?
https://youtube.com/shorts/UOwPRnXC8p8 |
04-04-2021, 04:32 AM | #2 |
Banned
Drives: 2010 LS Join Date: Feb 2021
I had the same issue, but was the passenger side that had more flow.
The driver side muffler was clogged. I stuffed a plastic bottle in the passenger side, and spiked the fuel pedal, to rev the engine. I had to repeat it several times, till the rev blew all kinds of shit out the driver side. Then it was fine. I had to repeat it, because the plastic bottle would shoot out the tail-pipe. Funny thing was, I could set the bottle in the driver side, and it would get sucked IN. Passenger side, it would blow out.. So, I knew there was a problem. What it was, the driver side, there was no material in the secondary cat, so it had to have gone somewhere... Brand new cats, they damaged somehow taking it off the rack, and the cat material was gone. There were visible dents in the bottom of the LH 2ndary cat. So, take a plastic 16 oz bottle, and set it in the right tailpipe, and see if it gets pushed out, or sucked in. Watch this: https://youtu.be/-xUXRvDfJnQ |
04-04-2021, 07:41 PM | #3 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
My cats were blown out and restricted flow to both sides. And plugged the passenger side more. Blew substrate into the xpipe and mufflers.
X pipe on mine, exhaust flow is equal. It's only on cold start?
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
04-04-2021, 07:45 PM | #4 |
lol, no cats here, and a straight thru flowing exhaust!! Only way to go.. lol.
04-04-2021, 07:58 PM | #5 |
#teamGPI
Yea it only happened on cold start because it was pretty cold in the morning and I could see it.
04-04-2021, 07:59 PM | #6 |
#teamGPI
04-04-2021, 08:34 PM | #7 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Amen to that!!!
