BORLA
Old 05-12-2017, 09:01 PM   #1
NVERL8TE
NVERL8TE's Avatar
Drives: 1967 Camaro BBC, 2014 Camaro ZL1
Post Boost meth
Is anyone here running a post boost meth set-up? I've heard that running meth pre boost on the ZL1 can wear the coating off the rotors. Opinions or other options?
NVERL8TE is offline   Reply With Quote
Old 05-12-2017, 09:11 PM   #2
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
before and after of meth...not worth it - stay in school
Hixson is offline   Reply With Quote
Old 05-13-2017, 08:55 AM   #3
NVERL8TE
NVERL8TE's Avatar
Glad you got treatment and could share your real life experience!
Old 05-18-2017, 02:57 AM   #4
N2O
N2O's Avatar
Drives: Camaro ZL1
Originally Posted by NVERL8TE View Post
I anyone here running a post boost meth set-up? I've heard that running meth pre boost on the ZL1 can wear the coating off the rotors. Opinions or other options?
in for the same information!
2013 Camaro ZL1 - CAI intake
N2O is offline   Reply With Quote
Old 05-21-2017, 05:28 PM   #5
DSX Tuning
Drives: 2012 CTS-V
Pre boost meth will have pretty much no cooling effect. Post boost is a much better option IMO. The phase change from liquid to vapor gives it a massive cooling effect which you won't get when spraying pre boost.
Austin, TX
314-322-3283 --- dave@dsxtuning.com
Flex Fuel - Fuel Pumps - Harnesses - Tuning - R&D
DSX Tuning is offline   Reply With Quote
Old 05-23-2017, 05:53 PM   #6
NVERL8TE
NVERL8TE's Avatar
Do you know of a complete setup that's available?
Old 05-24-2017, 07:17 AM   #7
ABADZL1
ZL1 Pilot
ABADZL1's Avatar
Drives: 2013 ZL1
https://prometh.com/collections/nozz...nt=32563342222
GP Tuning 2.5 Cam, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners
Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs
ABADZL1 is offline   Reply With Quote
Old 05-25-2017, 09:26 AM   #8
tailwind22
Drives: 15 ZL1
Can any folks comment on their results after installing post boost meth? Specifically how much additional boost lbs and timing was added and power results?
tailwind22 is offline   Reply With Quote
Old 05-25-2017, 10:40 AM   #9
Redbeard11
Redbeard11's Avatar
Drives: 11 camaro
After I went FI I was making 520/566. Dropped 1 pulley size and added a meth kit from alky control and went up to 576/566. Later did a btr 3 cam and went to634 at the wheel. Last week went back and added a second nozzle of meth and dropped pulley down 1 more to 3" and went to 675 at the wheel. These cars seem to love methanol ! Plus it cuts my air temperature by almost 40%. Watched it on the dyno myself. Can't go wrong in my opinion with it.
Redbeard11 is offline   Reply With Quote
Old 10-07-2017, 03:23 AM   #10
N2O
N2O's Avatar
Drives: Camaro ZL1
you were injecting meth before the throttle body?
