Old 08-12-2017, 12:44 AM   #1
incon3037r
GMHIC
incon3037r's Avatar
Drives: 2013 Camaro ZL1/2008 Pontiac G8 GT
FIRST ROUND OF MODS FOR MY Z
I've had my Z for a few months now and I've finally decided to do my first round of modifications. This week I purchased the following to have installed later this month. Is there anything I should add to this list?
Corsa 3" catback
Stainless works 2" primary LTH with RAM Proline 1400 degree ceramic heat coating
Injector Dynamics 1050x injectors (Squash or Fore fuel system in the future)
New Era 4.5" cold air intake with npt bungs for methanol (I'm not porting anything snout or blower, because I plan on upgrading to the heart beat or the R2650 blower in the future)
RSC PDx camshaft
BTR platinum .660 lift valve springs with titanium retainers
BTR hardened pushrods
Haven't decided on BTR trunnion kit or aftermarket rocker arms
ARP hardware, camshaft bolts, head bolts
NGK plugs
LS9 head gaskets
Misc GM gaskets
160 degree thermostat
AFCO ZL1 heat exchanger without fans (plan on adding expansion tank later on)
Innovators West LSA interchangeable balancer with Metco 9.55" lower drive pulley ring
Pontiac G8 GT- ProCharger F-1D, Treadstone TR1235 FMIC, Kooks 1 7/8" LTH,Corsa catback, New Era (228/240) cam, Yella Terra 1.7 Rockers, GMPP LS3 CNC heads, Aeromotive A1000, FAST fuel rails, FIC 1000cc injectors - 762 RWHP/646 LBFT tuned @ 9psi on E85 9psi using HP Tuners
Camaro ZL1- Stainless Works 2" LTH, Corsa catback, RSC PDx cam, ID 1050x injectors, DSX fuel kit, New Era 4.5" intake, BTR springs/pushrods, AFCO heat exchanger, New Era expansion tank, Innovators West balancer, Metco 9.55" lower - 609 RWHP/591 LBFT tuned @ 8psi on 91 octane using HP Tuners
incon3037r is offline   Reply With Quote
Old 08-12-2017, 03:22 AM   #2
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
You're going to need fuel you want be able to wait...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 08-12-2017, 04:09 AM   #3
incon3037r
GMHIC
incon3037r's Avatar
Thanks for the feed back
Old 08-12-2017, 10:26 AM   #4
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: 2013 ZL1 Convertible M6
Yep, you'll need to add a Boost-a-pump to that or the fuel system. And I'd go with a 10" lower for a lil extra power. Have you considered running on E85?
Can'tHave2MuchHP is offline   Reply With Quote
Old 08-12-2017, 07:12 PM   #5
incon3037r
GMHIC
incon3037r's Avatar
I was thinking the 9.5" lower would keep me around the 650 rwhp limit of the fuel pump. This is the same reason I didn't go with an upper. I ran E85 in my G8 and never had any problems, but recently it's been rumored that the E85 blend in Vegas is inconsistent, so I was planning on trying my hand at meth and running the Pro Meth ZL1 setup.
Old 08-12-2017, 11:14 PM   #6
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
You will still run out of fuel with a 9.55 pulley. So you need to consider fuel upgrades anyway you look at it.
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 08-12-2017, 11:28 PM   #7
Can'tHave2MuchHP
The difference between 9.55" and 10" is going to be non existent in fuel requirements, both need more fuel than stock fuel pump and ID1050s can provide.
Fair enough on E85. Meth injection can compensate nicely on it's own with 93, but if you're in Vegas you likely have 91 in which case you'll be needing to be putting a healthy dose of Meth into the system. You may want to get in contact with Ted Jannetty at Janetty Racing about fueling, he knows a lot about octane and power levels and can tell you what you'll need.
Agreed.
Old 08-13-2017, 05:23 AM   #8
incon3037r
GMHIC
incon3037r's Avatar
Agreed.
I appreciate all the feed back guys. I'll definitely start looking into different fuel setups and if need be, I'll dial it back until I decide which route I want to go.
Old 08-13-2017, 11:00 PM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
You have head gaskets and head bolts on your mod list but not any plans for ported or aftermarket heads? Why?
Old 08-14-2017, 05:27 AM   #10
incon3037r
GMHIC
incon3037r's Avatar
Great question. I'll have to look into having them touched up.
Old 08-14-2017, 09:45 AM   #11
gmorris
Drives: 2015 ZL1, Red Hot A6
What he meant was that if you aren't having the heads ported or swapping them out there is no need to remove them for a cam swap...therefore you don't need studs and gaskets.
2015 Red Hot ZL1, Rotofab, Kooks LT's, 9.55 lower, ID850's, JMS BAP, self tuned with HPtuners
1969 Chevelle, 418 LS3, Ridetech suspension
gmorris is offline   Reply With Quote
Old 08-16-2017, 09:55 AM   #12
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Corsa 3" catback
RSC PDx camshaft
NGK plugs
LS9 head gaskets
Misc GM gaskets
Agreed.
Thank you for the referrals, much appreciated.
incon3037r I would be happy to discuss your project and get you headed in the right direction with a very effective power package that will give you long life and great power.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 08-27-2017, 04:04 AM   #13
incon3037r
GMHIC
incon3037r's Avatar
So I've decided to go with the DSX auxiliary fuel system and added the NEP expansion tank to my list.
Old 09-09-2017, 08:03 PM   #14
incon3037r
GMHIC
incon3037r's Avatar
So my final numbers are listed on the dyno sheet below. I was hoping for more, but considering my baseline was low and the blower was only making 8 psi with the 9.55 lower and running 91 octane, I don't feel too bad. I'm sure if I add a 2.75" upper, port the snout w/ along with a larger throttle body, I can pick up some additional boost and hit 650+.
