SDTW Custom Wheels & Tires
Old 10-03-2017, 01:44 PM   #1
RareDarkness
Drives: 2013 ZL1 CAMARO
fuel pump options. advice please
2013 ZL1 M6
heres the current build - new upgrades in bold (previously factory size or part)
2.55 / 9.55 pulleys
1 7/8" headers - no cats
rotofab intake
ID850 injectors
LS9 cam
Ported blower and snout
Ported LS7 throttle body
AFCO HX
catch can
From what I can tell the fuel pump is maxed out around 4-4500 rpm.
I'm looking for a drop in upgrade as this will most likely be the end of power mods for the car.
I'm not trying to be to cheap. But I'm also not looking to buy something thats overkill for my application. I see a dual 340 (680lph) pump from Aeromotive Dual Phantom Fuel Systems, but reviews dont look to good.
I'm trying not to spend much more than $700 if I dont have to.
I'm not extremely well versed in fuel systems so any advice would be appreciated.
Thanks in advance.
RareDarkness is offline   Reply With Quote
Old 10-03-2017, 04:57 PM   #2
JB'sZL1
Drives: 2013 ZL1
You're running all that on the oem pump?
JB'sZL1 is offline   Reply With Quote
Old 10-03-2017, 05:01 PM   #3
Pogoattack84
Shred Till I'm Dead
Pogoattack84's Avatar
Drives: 2013 ZL1 Summit White
Do you ever plan to run E85?
2013 Summit White ZL1 W/Recaros
Mods: Roto-Fab CAI, Stainless Works 3" Exhaust, 1-7/8" Stainless Works LT Headers, 2.55 Griptec Upper, Metco Damper, 9.1" Metco Lower Ring, Metco Solid Isolator, Metco Idler Relocation Bracket/50mm Idler, Texas Speed Heads/Pushrods/Springs/Retainers/SS Valves/Custom Grind Cam, ARP Bolt Kit, DMS Auxiliary Fuel Pump Kit With Flex Fuel Sensor, ID1300 Injectors, Lingenfelter Dual Fan HX, Lingenfelter 160 Degree Thermostat, DMS Expansion Tank
Tuned By Dedicated Motorsports - 750whp/14psi/E85
Pogoattack84 is offline   Reply With Quote
Old 10-05-2017, 05:11 PM   #4
ABADZL1
ZL1 Pilot
ABADZL1's Avatar
Drives: 2013 ZL1
JMS Bap is all you need.
GP Tuning 2.5 Cam, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners
Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs
ABADZL1 is offline   Reply With Quote
Old 10-05-2017, 06:27 PM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2014 ZL1
What he said
2014 Red Hot #1503 | 629 SAE | JRE Remote Cal | RotoFab | 28% OD | 1-7/8 LT's | JMS BAP | ID850 | TR7IX | MSD Wires | Monster LT1-S Triple |
RobZL1 is offline   Reply With Quote
Old 10-10-2017, 10:29 AM   #6
2NASSTY
2NASSTY's Avatar
Drives: 14' ZL1 96' Impala SS
Agreed. I just put my JMS BAP up for sale due to new motor build. Has about 5000 miles on it.
http://www.camaro5.com/forums/showthread.php?t=509999
14' Crystal Red Tintcoat ZL1 6M, 10.460 at 136.57 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 10-10-2017, 02:34 PM   #7
robrocketanski
robrocketanski's Avatar
Drives: ZL1 Convertible Auto
I also think a fuel pump voltage booster could be enough. It's a lot cheaper and easier than any pump replacement. But you have to try it to know for sure. You can do what I did and duct tape a fuel pressure gauge to your windshield to live monitor fuel pressure.
RPM 5" intake, Nick Williams 102mm TB, F.A.S. ported snout and blower, 10" ATI lower and 2.75" ADM upper for 40% overdrive, 1 7/8 headers no cats and 3" header back, JRE smooth cam, ID1300, Fore dual 430lph pumps with MSD voltage booster, A6, 305/45/17 Mickey Thompson Street R
robrocketanski is offline   Reply With Quote
Old 10-10-2017, 03:35 PM   #8
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2014 ZL1
Not sure what your goals are for the car or if you have any longevity concerns, but you might want to look at a 10" lower upgrade instead of adding the 2.55. The 2.55 puts you right up there in the blower speed danger zone, if we are to believe the lingenfelter or weapon x charts.
Old 10-10-2017, 08:02 PM   #9
Can'tHave2MuchHP
God - Family - Country
Can'tHave2MuchHP's Avatar
Drives: ZL1, Z06, Duramax, and More
I’ve given up recommending pulleys to people. Everyone thinks they can just bolt on whatever and the more overdrive the better. Not so. All you do is add heat above 35%.
OP a BAP is probably all you need.
Can'tHave2MuchHP is offline   Reply With Quote
Old 12-31-2017, 08:39 PM   #10
Deez-zl1
Deez-zl1's Avatar
Drives: 2013 camaro zl1
This is a little off the subject. I hav a bap now making 650 rwhp. I hav cam, pulleys, injectors etc.. Will this bap suffice on E85 ? I'm figuring 700ish to the wheels
Deez-zl1 is offline   Reply With Quote
Old 01-01-2018, 07:12 PM   #11
robrocketanski
No.
You need either 2 new pumps or the DSX aux pump. You might be able to run E50-60
