09-15-2017, 06:04 PM | #1 |
Drives: Camaro 2SS 2013 Join Date: Sep 2014
SS2 Camshaft and Lope
Hey all. I have GPI SS2 cam.
Is it possible to custom grind a cam and keep power and torque like GPI SS2 VVT but with completely stock idle and stock like quiet. Sort of sleepers cam. I love SS2 cam but want to keep same as stock idle and quiet. No lope at all. Loud while driving is no issue at all. I have upgraded all nessecary parts for L99 VVT cam. Just i will swap cam to custom grind SS2 VVT. Any possibility
Camaro 2013 2SS/RS L99 VICTORY RED
VMAX PORTED THROTTLE BODY, ROTO-FAB CAI, FLOWMASTER OUTLAW AXLE-BACK WITH J-PIPES. VITESSE THROTTLE CONTROLLER. 1LE 3.91 GEARS. KOOKS 1 7/8 LTs, CAT DELETE, GPI SS2 VVT CAM, ATI 10% UDP, MELLING HIGH VOLUME HIGH PERFORMANCE OIL PUMP |
09-15-2017, 06:33 PM | #2 |
in a word...no! Those lobes are what make the power. You could try quieter mufflers,
09-15-2017, 07:00 PM | #3 |
Call Ryan at GPI or send a PM and ask him. He would know best on what you can do with a custom grind. His forum name is rhino79
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
09-15-2017, 08:07 PM | #4 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
That is the unfortunate part of a pushrod engine. You are limited by a single set of cam lobes. You will not get big power without having that lope. Only dohc engines have the ability to tighten and open LSA, which helps a lot with controlling lope. There are grinds that are very mild, like the LS9 cam etc, but they don't make nearly enough power to be considered worth the hassle imo.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
09-16-2017, 08:25 AM | #5 |
old school chevy rodder
You will also find almost all aftermarket cams also require a higher idle which does counter some of the lope sound but with our lift...And why ???? Why kill the lope that is loved world around to try to make a sleeper so bad when you can kill most the sound with the exhaust.
09-16-2017, 08:43 AM | #6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
"Kill the Lope" Seems as crazy as a lot of the other things going on around me lately. Love the Lope...
(no cams were harmed in the posting of this message and I approve) - MM
09-16-2017, 08:58 AM | #7 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
After reading many of your post....my best advice is to just go back to stock. I hate to quote old cliche....but you cant have your cake and eat it too.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
09-16-2017, 04:05 PM | #8 |
Dont want to go back to stock. As power is amazing. Car pulls like crazy till 7000 rpm.
Ok one more thing. Drilling a hole 1/8 inch into throttle body will cure the cam shake inside the car. As it will get more air at idle? I have one extra throttle body with me. Should I try?
09-16-2017, 09:23 PM | #9 | |
Drives: 2017 Silverado Join Date: Mar 2017
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis |
09-16-2017, 10:42 PM | #10 |
What this guy above me said.
09-17-2017, 01:54 AM | #11 |
USA-1
Go back to stock exhaust other than the longtubes. :P
Do you have a stall? I don't see that in your mod-list...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
09-17-2017, 05:30 AM | #12 |
Hahah noo tuner is best. RYAN himself tuned it. Car runs perfect. Other than cam shake.
No I dont have stall converter. It is on stock converter. Car only bucks while decelerating and dipping under 1200 RPM. Slow speeds are good as well. I am on stock exhaust with cutouts. Sound is almost good now. Will upload a clip. Butttt cam shake . Shakes my b.......
09-17-2017, 07:56 AM | #13 |
I would suggest a higher idle and no drilling a hole ......STUPID ...great way to ruin a TB.
