Old 09-09-2018, 06:54 PM   #1
NOVAK
NOVAK's Avatar
Drives: 2015 ZL1
NPP Flaps Not Working w/ Mild 2 Wild
I just installed the Mild 2 Wild and the NPP flaps do not switch. I can hear the clicking noise coming from the Mild 2 Wild box when I press on or off on the remote, but nothing happens. I successfully programmed the remote to the MyLink buttons as well. Everything was installed correctly so I’m wondering if I missed something or there’s a deeper issue that needs to be discovered. Any ideas?
NOVAK is offline   Reply With Quote
Old 09-09-2018, 08:02 PM   #2
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Wish i could help my man, i have a Forza 3 way controller... no remote.
Double check that everything is hooked up correctly... NPP working prior to install?
Where in CA are you?
Crash76 is offline   Reply With Quote
Old 09-09-2018, 08:39 PM   #3
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Don't really know but;
So if you squat back there (with eye protection, sunglasses at least, don't want that metal packing goin in your eyes that's BAD) and see if the flaps actuators move upon initial startup in the OEM configuration? That was you can see if the vacuum lines and valves and actuators are working. If yes, Then see if a proper signal is coming out of the module, I don't recall if it was 12v electrical to a vacuum valve or what.
silversleeper is offline   Reply With Quote
Old 09-10-2018, 11:23 AM   #4
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
Have you rev'd it up or taken it for a drive to determine if the flaps aren't working?
The flaps are always open at idle, so you won't hear them close/open unless you rev it up a bit, or take it for a spin and get the car up past 1k rpm.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
Old 09-10-2018, 11:41 AM   #5
Silveradoss573
Drives: Camaro 1LE
^^^this^^^
Silveradoss573 is offline   Reply With Quote
mild 2 wild, npp exhaust, zl1
