10-26-2013, 10:47 PM | #1 |
Drives: MANual Join Date: Jul 2013
Took Bumper Off..2 Blocks fell
So I took my bumper off to put splitter on. And as I pulled each side on the bumper, when it came off a little wooden block painted black fell off (one on each side) what is this? I don't know if I should put it somewhere. I did not see where it fell from.
Each block was around 4 inches by 3 inches. edit: took some pics of inside but I doubt you could see much. Also the side of the bumper there was tape if you can see. Last edited by Supreme Leader; 10-28-2013 at 07:11 PM. |
10-26-2013, 11:30 PM | #2 |
Drives: 2012 45th Anniversary 2SS LS3 Join Date: Feb 2012
Wooden blocks? Are you sure they were wood? Post some pics when you can.
I've taken my bumper off about half a dozen times and have never had any blocks fall off.
10-26-2013, 11:33 PM | #3 |
Are you the original owner and do you have the original bumper? There shouldn't be any wooden blocks on your car. I have taken my bumper off of both my Camaros several times and have never had anything fall out.
10-26-2013, 11:43 PM | #4 |
I've never seen any blocks.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
10-27-2013, 01:00 AM | #5 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
Pictures would help. I think that a body shop may have took the "easy" way out when alligning a damaged bumper and used them
10-27-2013, 10:10 AM | #6 |
Drives: SRT Yugo GT Super Sport with Manual Join Date: Mar 2012
Sure they are not hard foam?
10-27-2013, 10:51 AM | #7 |
Drives: 2012 camaro Join Date: Oct 2013
post some pics of the blocks so we can tell what they are
10-27-2013, 10:54 AM | #8 |
Drives: 2013 Camaro 2SS RS LS3 Join Date: Feb 2011
I have had my bumper off and there were no blocks, (wood, plastic, foam, or otherwise), that were anywhere. Someone has added these. Where were they?
-2013 Summit White over Inferno Orange 2SS RS- -2014 White Diamond Silverado Z71 Crew Cab Short Box- |
10-27-2013, 06:26 PM | #9 |
Sorry I took the pics last night but forgot to upload. And I bought it barely used with no accidents.
10-27-2013, 06:36 PM | #10 |
Drives: COTW 8/29/11 2010 CAMARO Join Date: Jul 2009
Maybe when it went up in space caught some debris up there
10-27-2013, 06:48 PM | #11 |
Drives: 2010 rs 2lt Join Date: Aug 2012
hmmm wood blocks , what a concept ! A new Mod !
10-27-2013, 06:57 PM | #12 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
You may be able to figure out where they came from by matching the shape of the area that didn't get painted to a similarly shaped area on the bumper.
10-27-2013, 07:05 PM | #13 |
Drives: Camaro 2010 Join Date: Jul 2010
Just had my bumper off recently. No foam or wood blocks.
10-27-2013, 07:06 PM | #14 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
They kind of look like shims...
