Old 12-27-2014, 05:12 PM   #1
z3R0fo01
z3R0fo01's Avatar
Drives: 2014 1SS RS 1LE tvs2300
larger clutch fluid reservoir
I have the separate reservoir but it gets dirty very quickly. Does anyone know of a place where I guy buy a much larger one? Just a good quality generic one, I can make a bracket out of aluminum or stainless.
z3R0fo01 is offline   Reply With Quote
Old 12-27-2014, 05:19 PM   #2
Bo White
Bo White's Avatar
I hear a sponsor on here is working on one made of nice billet.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-27-2014, 05:24 PM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Mine seams large enough . A larger one would just get more dot 4 dirty and cost more when you change the fluid .Most of us get the GTO clutch res ,you can get it at any Chevy dealer orat GMpartsdirect.com
GM part # 92065790
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 12-27-2014, 05:54 PM   #4
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
What we are working on is similar to the stock reservoir, but the clutch fluid is separate inside of the master cylinder reservoir, and has it's own cap. The feedback I have received from the road race and auto-x guys is that the GTO res doesn't have enough capacity to not fade by the end of the track weekend without changing the fluid at least once. In addition, the stock master res is pretty ugly, so with our one piece unit it will eliminate those covers that people use for the caps and the res, and there will be no extra hose nipple like when you separate the reservoirs, plus less clutter in the engine bay. It may not be a solution for everyone, but we are looking to kill more than a couple birds with one stone.
2012LS3VERT is offline   Reply With Quote
Old 12-27-2014, 06:27 PM   #5
z3R0fo01
z3R0fo01's Avatar
Thanks for the feedback. I have the GTO with the L99 stock reservoir and yes it gets dirty very very quickly.
I was looking for something that could replace the GTO reservoir. Just something with the same nipple size, 3/8 I think. I have everything I need to make a bracket. I might just get my brother to fabricate a reservoir.
Also, I would be interested in an all in one, just one word of advice: make it big! Like equal the size of the stock reservoir. When do you think you might have a prototype that we can check out?
Old 12-27-2014, 06:50 PM   #6
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
What material are you going to use to make the reservoir? similar to what is OEM? How soon before you have some samples?
Old 12-27-2014, 07:12 PM   #7
2012LS3VERT
It will be anodized aluminum, with proper EPDM diaphragm cap gaskets. The problem with some of the other billet reservoirs is that they use an oring, forcing them to use a vent system that exposes the fluid to air. We will more than likely offer a separate reservoir that holds more than the GTO one but with more capacity, that uses the same mounting and hose to make it a direct swap for those that have one already, but it will be after the full replacement is produced. As to timeframe, I believe we are starting Monday on 3D modeling and prototyping. We would actually have had these done, but we received a lot more orders for our solid subframe bushings than we anticipated, so we had to knock out a second run of them for those individuals that wanted to make holiday orders. I am getting back on this project now that we are caught up on those and the trailing arms/toe rods.
Old 12-27-2014, 07:47 PM   #8
HoustonTx2ss
HoustonTx2ss's Avatar
Drives: 2010 2SS RS M6
I was looking at ordering this one. 7oz reservoir. I don't know for sure but for $16 If it is not good, it wont be much lost. Anyone have experience on this one?
http://www.summitracing.com/parts/wil-260-11098
2010 SS/RS M6-LS3 -- Mods -- CAI, V-Max Throttle Body, Apex Scoop, SP 1 7/8 Headers, HF Cats, Magnaflow Tru-X.
Dyno Tuned by Mike (FAST Automotive) and Matt (FSP)
BMR Suspension - Rear - Cradle Bushings (Pro Version), Upper Control Arm Bushings, Diff Bushings, Trailing Arms, Toe Rods, Drop Spring, Koni STR.T Struts.
HoustonTx2ss is offline   Reply With Quote
Old 12-27-2014, 07:54 PM   #9
2012LS3VERT
It should work, two possible issues: if the hose is regular rubber, it may not last a long time, and it is listed as using a 1/4" hose, so it may restrict fluid flow enough to cause a second gear grind, as opposed to the approximately 3/8 stock hose.
Old 12-27-2014, 11:30 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What if you used a reducer in reverse on both ends of the hose and use a larger lines say 7/16ths or 1/2 so the line itself could be a partial reservoir itself???
Old 12-27-2014, 11:59 PM   #11
2012LS3VERT
It might add a negligible amount of fluid, but flow would be restricted by the smallest orifice diameter, especially since the fluid in the reservoir is not under pressure, just suction. Adding to the total fluid volume aids in reducing the total percentage of contamination in the fluid when the slave cylinder strokes, so it takes longer for the fluid to degrade to where it becomes necessary to change it.
Old 12-28-2014, 11:15 AM   #12
z3R0fo01
z3R0fo01's Avatar
I might try this
http://www.summitracing.com/parts/wi...8742/overview/
Old 12-28-2014, 11:22 AM   #13
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
subscribed
Camaro Dude is offline   Reply With Quote
Old 12-28-2014, 11:47 AM   #14
2012LS3VERT
Originally Posted by z3R0fo01 View Post
I would get the 4oz version, that one is the 10. It might be kinda big to fit in there. I was looking at the 4oz version, but I was trying to see if it had a vented cap or a diaphragm cap.
