Old 09-09-2012, 02:11 AM   #1
McSleepyx9
McSleepyx9's Avatar
Drives: 2012 SW 1LT
Oil Change
hey all,
well i have a very dumb question to ask but i honestly dont know lol, im not much of a car guy and this is my first synthetic car so i dont know how stuff works. But my question is after how many miles should i get an oil change? My car is at bout 4,2** miles right now and i got it with 400 miles on it. And on the dash board, on the panel thing where it says Oil Life its at about 25%, do i change it when its reaching 0%? Or when should I do it? Also, anyone have an idea how much an oil change is for the v6 LT camaro?
Thank you!
McSleepyx9 is offline   Reply With Quote
Old 09-09-2012, 02:23 AM   #2
eastwoodisme
Drives: 2010 LS3 CGM 2SS Camaro
The oil life indicator is a very intrinsic and sophisticated system that GM has perfected. It calculates based on several things like RPM, temperature, mileage, etc. I have a V8 but I would say at 25% you should start getting ready to make the change. The system will notify you on your dash at 5% i believe is what it is. Don't go until 0% but don't change it at 30%. Any where in that range should be fine. As for the mileage synthetic can be pushed a lot further than conventional.
Also again I don't know what oil you require however the Mobil1 for the V8's run at $8.99 a quart here in Texas.
Hope this helps.
eastwoodisme is offline   Reply With Quote
Old 09-09-2012, 02:47 AM   #3
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
I did mine at 500, 1500, then at 3000, 10000 and then when DIC would get to about 25% or if I was going to track. But thats just me. I am at 50k now and she runs like new.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 09-09-2012, 03:42 AM   #4
Travis64
Travis64's Avatar
Drives: 2011 Camaro 1lt rs auto 4-9-11
always do your 1st oil change early because of all the metal shavings in it.so do it now!
did mine at 1500 then at 4000 now i just change it at 35-50%
Travis64 is offline   Reply With Quote
Old 09-09-2012, 10:08 AM   #5
Candy_Camaro
Amanda
Drives: 2014 ZL1
Go off of oil life or look up Chevy's recommended intervals. It used to be 3 months or 3000 miles but most manufacturers now say 5000-7000 miles.
Candy_Camaro is offline   Reply With Quote
Old 09-09-2012, 10:26 AM   #6
rydahog
rydahog's Avatar
Drives: camaro ss
That dash panel thingy is your DIC. so check your DIC periodically, you can touch your DIC and see if its up or down, from the last time you checked your DIC. Then it will tell you what is going on. Make your choice about what to do depending on what your DIC shows. hope that helps.
rydahog is offline   Reply With Quote
Old 09-09-2012, 01:19 PM   #7
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
I would change it now. I don't pay much attention to what the oil life meter says. I changed mine at 1500, and I plan on doing every 5K miles or so after that.
E.T. is offline   Reply With Quote
Old 09-09-2012, 07:21 PM   #8
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
Hope this helps.
Or after 1 year as I don't put enough miles on it per the oil monitor.
cmore is offline   Reply With Quote
Old 09-09-2012, 08:05 PM   #9
STW
STW's Avatar
Drives: 2011 Camaro 1SS/RS LS3
I drive in heavy traffic. When not in that, I ROAR through the gears often. I change every 4K ish. I have 42K miles, today, it runs like a top.
STW is offline   Reply With Quote
Old 09-09-2012, 08:12 PM   #10
DeAdMiKe187
Drives: Black 2012 2LT
The technicians at my dealership recommend changing it at 20%.
DeAdMiKe187 is offline   Reply With Quote
Old 09-09-2012, 08:26 PM   #11
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
Oil is cheap insurance, as are filters. I do mine every 3-4, 000 miles. Never had a car wear out. 'nuf said.
Bonanza7 is offline   Reply With Quote
Old 09-09-2012, 08:40 PM   #12
SimpleGreen
Drives: 2015 2SS/RS
I changed mine at 1500 miles or so. I'm at 5300 right now. I'll probably do it every 5K-7K even though OnStar said it would be good to around 11,000 miles LOL.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 09-09-2012, 08:48 PM   #13
Neto1978
Drives: 2011 camaro ss victory red
50% of life oil system is a good time to change the oil...simple and cheap insurance...
Neto1978 is offline   Reply With Quote
Old 09-09-2012, 09:01 PM   #14
pooch
pooch's Avatar
Drives: 2013 2SS Dusk convertible
This is pretty much what I do.
pooch is offline   Reply With Quote
