Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California > Local Marketplace
Old 04-28-2015, 05:59 PM   #1
2010SSRSM6
2010SSRSM6's Avatar
Throttle bodies, Headers and axle back, ZL1 pump and ADM FPCM
I'm scheduled to make some major changes to my car on the 18th of May and have several things either coming off the car or sitting in my garage and they are in need of finding a new home. If they are on the car, they will not be available until CMS has a chance to get them off the car. Unfortunately where they are on the car, pic's will have to wait. I'll try to get pics of the other stuff on here A.S.A.P.
Throttle bodies:
I have the following throttle bodies that I will be parting with.
BBK 95MM: I've ran this on my car for 30k miles and had ZERO issues with it. I'm getting a developmental TB and will no longer have a need for this one. It is currently on my car and will have to wait until after the 18th before it is available.
SOLD!!!
Electronics not included.
BBK 102mm: This TB has roughly 10k miles on it. ZERO ISSUES with it. It has been modified to work with a Magnuson jackstaff version TVS2300 (notched). If you have a blower, you would greatly benefit having a ported snout if you are going to run anything larger than the 95mm. That being said, I did pick up 10rwhp over the 95mm without tuning and I'm sure it would have picked up more with the tune. This would be going on my car on the 18th, but I'm testing another product so I can't.
Retail $399 Asking $300 o.b.o.
VMAX ported factory TB in Inferno Orange: I am currently using the electronics off this TB on my BBK TB that is on the car. This TB has less than 4k miles on it, but the electronics has about 30k miles on them. This will not be available until after the 18th where I still need it on the car.
Retail $150 (plus $150 core, shipping on your original plus $50 for powder coating or $350 up front cost)
SOLD!!!!!!!
Headers:
1.75" BBK long tube headers. These are an early pre-production version. They have bungs welded onto a runner on each side for A:F sensors if you want to run a dual band A:F gauge. I also have the Catted mid pipes for these. Where I was running these on my car with the blower, one of the cats melted the internals and it would be best if the buyer were to remove the internals. I also have off-road pipes in case you don't want to run cats. These are currently on the car and will not be available until after the 18th.
Retail $799 Asking $400 o.b.o. SALE PENDING.....
Here are the High Flow Cats. You can see they need to be gutted.
Axle Back
JBA Axle Back exhaust. This will work with both the standard rear valence as well as the GM GFX rear valence. This is the 2.5" system that mates up to the factory H-pipe.
Retail $550 (JBA lists it for $775 but I've found it cheaper) Asking $300 SALE PENDING......
When paired with the BBK headers my car put out over 125dB during multiple sound off competitions with the loudest being 131dB. If you want a loud and throaty sound, this is the combination that you want. If someone wants the LT's and the axle back together, I'll take $100 off asking price and you can have the entire assembly (including the factory H-pipe that is currently modified for the axle back so you don't have to cut your stock system up)
ZL1 Fuel Pump
I've run this pump for just under 10k miles. I'm converting to a dual pump setup to run E85 and this will not keep up. With Bosch 1000 injectors, it was able to keep up with 620rwhp without dropping pressure on a dynojet dyno (590rwhp on CMS's Mustang and Dyno Dynamics dyno's). I'm not sure if the float is needed for the new setup, but I don't believe it is.
ADM FPCM
If you are going to run the ZL1 pump, you have to have this FPCM in order to get the benefit of the pump. Both of these were installed together and will be sold as one unit.
SOLD!!!
Spectre CAI
I had this powder coated black and it highlighted all the blemishes that were unseen in the tube prior to powder coating. If you want a CAI that works, but looks like its seen its better days, you can have it.
Can't find the filter........Keeping it for now.....
[B][U]RX Catch can in Orange. SOLD!!!!!!
Mounted to the car but never plumed. I do not have the vacuums hoses but you can get that at any auto parts store for $1.59 per foot. I want to say they came with automatic transmission line.
SOLD!!!!
I'm located near Temecula and willing to drive to meet to save on shipping. If you want it shipped, shipping is the buyers responsibility and you will only be responsible for actual shipping charges from 92585 to you.
If you want multiple items, I'm open to a group discount.
Pic's of items currently in my garage will be posted shortly.
Old 04-28-2015, 07:07 PM   #2
Tim417
Drives: 2013 Camaro 2SS
I am on schedule to be back at CMS next month. Sounds like you are having a bunch of stuff done! If I may ask, what are your mod plans?
Tim417 is offline   Reply With Quote
Old 04-28-2015, 08:11 PM   #3
2010SSRSM6
2010SSRSM6's Avatar
Ported blower, 8 rib, squash, E85, larger exhaust, alky meth kit and a couple small tweaks.
Old 04-29-2015, 12:35 PM   #4
Tim417
That's awesome! You're gonna make some scary power. Hope to see your car there when I come in. I'm also getting an alky control methanol kit installed next month. After that, I gotta see how much the driveline can handle before adding more power.
Old 04-29-2015, 12:57 PM   #5
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
So you are not willing to separate the ADM FPCM from the zl1 fuel pump? I already have a zl1 fuel pump and getting the injectors and flex fuel sensor kit to run e85.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 04-29-2015, 05:08 PM   #6
2010SSRSM6
2010SSRSM6's Avatar
You're the second person to ask me to split them up. If I can't get a buyer for the combo, I'll split them up, but I'd like them to go together so someone else isn't in a similar situation.
ZL1 pump is only going to be good for about 520rwhp on E85.
Old 04-29-2015, 05:35 PM   #7
krisprz2010camaross
Ok let me know if you split them. And I'm staying naturally aspirated.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 05-02-2015, 03:34 AM   #8
2010SSRSM6
2010SSRSM6's Avatar
Pics will be up by Monday of what's in my garage.
Old 05-05-2015, 12:15 PM   #9
2010SSRSM6
2010SSRSM6's Avatar
Pics added along with catch can.
Old 05-05-2015, 07:09 PM   #10
2010SSRSM6
2010SSRSM6's Avatar
Catch can sold!
Old 05-05-2015, 08:25 PM   #11
krisprz2010camaross
So are you willing to sell ADM FPCM separately? And any pics?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 05-06-2015, 11:11 AM   #12
2010SSRSM6
2010SSRSM6's Avatar
I will have pics after it comes out after the 18th. It's a PITA to pull the panel back just to take a pic.
I'd like to keep them together until the 1st to give someone a chance to get the complete setup. If I get someone wanting just the pump before that I'll split them up.
Old 05-06-2015, 11:13 AM   #13
2010SSRSM6
2010SSRSM6's Avatar
Should put me near 750rwhp. That's as far as I'm pushing the stock bottom end and transmission.
Old 05-06-2015, 01:56 PM   #14
krisprz2010camaross
Ok no worries, thanks.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
