04-29-2017, 08:46 AM | #1 |
Drives: '15 ZL1 Join Date: Apr 2017
New guy here!
Hey guys! Just picked up a A6 '15 ZL1 that I traded my cammed/bolt on '03 C5 Z06 for. Couldn't be happier! This car will not stay stock for long .. Drag raced it last night and the best I could do was a 12.4 @ 116. It was 88 degrees so that wasn't doing me any favors. My plans are rear 18" black repro wheels wrapped in 305/45/18 M/T ET street R's, 10.1 lower pulley/ stock upper, Rotofab CAI, TSP 2" headers/xpipe, and dyno tune. Most likely a cam down the road. I'm not new to the fbody (had a LT1 fbody in the 90s) but new to the Camaro5 community, good to be here!
04-29-2017, 11:30 AM | #2 |
Drives: early 2011 Camaro convertible Join Date: Jul 2014
welcome
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust |
04-29-2017, 12:21 PM | #3 |
Drives: Fast Join Date: Mar 2015
Welcome to the Forum. But your mod list needs a little bit of a revising . Feel free to ask questions.
04-29-2017, 12:37 PM | #4 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
Mod list looks great. Can't wait to see the results.
WELCOME to the ZL1 club!
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
04-29-2017, 02:28 PM | #5 |
04-29-2017, 03:12 PM | #6 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
That 10" pulley is going to require a lot more fuel. So you are going to need bigger injectors and a BAP
Bryan 2018 ZL1 M6
04-29-2017, 04:43 PM | #7 | |
I'm not saying you can't do it, you can, and when/if you add a cam, you'll pick up lots of power and drop the pressure. For cams, there's plenty, though I really like the BTR stage 3 cam. |
04-29-2017, 06:03 PM | #8 | |
With a big increase in boost your DCR(dynamic compression ratio) is so high that the engine is prone to detonation. Therefore you have to pull all the ign timing advance out to prevent knock. And there goes all your power. Unless you run race gas all the time. Now DCR is based on static compression ratio, boost pressure, and intake valve closing point. With a bigger cam (longer duration) the intake valve closes much later. So your DCR comes down and then you can advance the timing back up closer to MBT(maximum brake torque) timing. Also you are going to run cooler because the boost pressure comes down (google "adiabatic compression") This all goes back to the notion that any engine modification that results in better airflow will lower your boost. And that is a GOOD thing despite the general consensus on the internet that if you lost boost you lost power. Here is a good DCR calculator you can download. http://cochise.uia.net/pkelley2/DynamicCR.html
Bryan 2018 ZL1 M6
04-29-2017, 08:18 PM | #9 | |
04-29-2017, 09:42 PM | #10 |
Drives: 2013 ZL1 Camaro 2000 SLP Camaro Join Date: Oct 2012
Welcome. And good luck with your mods.
2013 ZL1 748rwhp & 733 rwtq ( 93 tune )
04-29-2017, 10:57 PM | #11 |
Formerly RJT2SSRS
Drives: 2013 ZL1 Join Date: Jun 2016
Welcome DaveZL1 to ZL1 info command. Great info in the forum:-)
04-30-2017, 01:32 AM | #12 |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
04-30-2017, 07:30 AM | #13 |
Drives: 2012 ZL1 Automatic Join Date: Apr 2011
Welcome Dave...and 116mph Stock in that Heat is Great!
2012 Chevrolet ZL1
Automatic |
04-30-2017, 09:05 AM | #14 |
Drives: 2015 ZL1 Join Date: Jun 2015
Welcome to the club!
2015 ZL1 M6
