#Camaro6
Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Engine Internals
Old 04-25-2023, 11:04 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Soler Performance Premium Modified 87mm Throttle Body SE8223-040-CAM For 2016-2023 Ca
Soler Performance Premium Modified 87mm Throttle Body SE8223-040-CAM For 2016-2023 Camaro Ss
The 2016-2023 Camaro SS Soler Performance Premium Modified 87mm Throttle Body increases air intake for more power!
FEATURES:
• Optimized Active Contours (Both Upstream & Downstream)
• Porting Taper and Upstream Bore (Lip & Bore Reduction)
• Greater Discharge Coefficient of Plate/Blade
• 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction)
• Half-Shaft (Front & Back) for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Minimized Gear Backlash
• Countersunk, Thread-locked, and Peened Screws
• Made from Brand New OEM Parts
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience (We doubled the rate of change of mass airflow (MAF) from 1.2 g/s-deg to 2.4 g/s-deg), 100% Increase!
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
APPLICATION: 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023 CAMARO 6 SS
southerncarparts is offline   Reply With Quote
Old 07-19-2023, 12:12 PM   #2
wang970305
Drives: 2021 Camaro SS
can the stock tune handle this and a CAI?
2021 Camaro 2SS Summit White, Roto-Fab CAI, GPI-LT2 IM, Corsa Extreme+ variable with sec cats delete, Mishimoto catch can.
wang970305 is offline   Reply With Quote
