03-10-2018, 09:14 AM | #1 |
Drives: 2017 ZL1 Join Date: Jun 2017
Cam Choice
What goes into your guys decision in picking the right cam for your car? They all pretty much cost the same, seems like most shops all have different levels of their own “custom grind” cam, what leads you guys to your decision on which one you go with, also as opposed to a stage 1-3, why not always just go with the highest stage if it is giving you the most HP?
03-10-2018, 09:25 AM | #2 | |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
03-10-2018, 10:18 AM | #3 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Since your car is FI, you may want a cam with a wider LSA and perhaps negative overlap.
________________________________________________
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
03-10-2018, 11:28 AM | #4 |
Drives: Fast Join Date: Mar 2015
Bigger cam = more power
Bigger cam also = bad drivability You want to balance in the middle unless you have a desire for either stock drivability (Smaller cam) or just all out peak HP and no care about drivability (Bigger cam). Personally, I've driven a C7 Z06 (LT4, same as the ZL1) with a Vengeance Stage 3 cam, car put down about 775 RWHP and had power everywhere. You can look up their youtube channel for some videos on lope, drivability and the like on their YouTube channel. Don't just get a massive cam because you can. You'll break more parts and the car will be harder to drive (High revs off idle, bucking, stalling, no down low power, etc.). |
03-10-2018, 12:21 PM | #5 |
Drives: '21 ZLE A10 Join Date: May 2012
bigger cam has a rough idle and may sacrifice a little low end torque. In the LT4, supercharging will negate some of this torque loss or it will be less noticeable. Higher lift cams can be harder on valvetrain parts such as valve springs and rockers. For road racing, a high lift cam can be really tough on parts and it has been suggested to try a cam with lower lift numbers. It depends upon your use and hp goals.
03-10-2018, 01:59 PM | #6 |
What is AFM/DOD delete?
03-10-2018, 02:02 PM | #7 |
Hmmmm...
active fuel management/displacement on demand |
03-10-2018, 06:57 PM | #8 | |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
03-10-2018, 08:30 PM | #9 | |
03-10-2018, 08:46 PM | #10 | |
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
Even my compound boost cam for my 427 is a phenomenal daily driver and the thump makes Zeus proud! https://weaponxmotorsports.com/searc...+gen+6+cam+kit |
03-12-2018, 12:35 AM | #11 |
Drives: 2018 ZL1, Cadillac ATS-V Join Date: Feb 2018
For me, I will chose a simple cam that will keep the ZL1 driveable, add some power and will stand future mods.
03-12-2018, 07:16 AM | #12 |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
How is the lope sound on a smaller stage 1? I had a decent size cam in a previous Vette and it bucked like hell at idle and ended up causing issues. As silly as it may sound, with a Zl1 I’m not looking for any more power - simply the joy of hearing the lope with headers. Just curious if the 1 is underwhelming
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
03-13-2018, 02:28 PM | #13 | |
