02-20-2010, 11:22 AM | #1 |
Drives: 2010 Camaro SS 6M Join Date: Feb 2010
Question about Eibach installation
Just ordered my Eibach springs. Do I have to cut the bump stops 1 inch as pfadt instructions say we have to? Appreciate any advice, thanks!
02-20-2010, 12:23 PM | #2 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
you do not have to cut bump stops for eibach kit as it is 1"
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
02-20-2010, 12:36 PM | #3 |
Firefighter/Paramedic
Drives: RJT 2SS/RS M6 LS-3 Join Date: Aug 2009
I had the same question before I installed mine. I called Eibach directly, they said it was not necessary for the 1.0 kit. They also told me they were in thr process of making new struts. If in the event I replace my struts with new Eibach struts, I would have to cut the bump stops. Hope this helps
FFPM73
02-20-2010, 06:00 PM | #4 |
Thanks a lot guys for the advice.
you guys noticed any difference in ride stiffness after the eibachs |
02-20-2010, 06:14 PM | #5 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
i am cutting mine 1" when i install them, might as well do it when they are apart, it wont hurt anything and it will guarantee that you wont bottom out on them
Similar Threads | ||||
Corsa installation question...... | 2010SSRS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 02-15-2010 03:27 PM |
Question Involving 4.10 gears & Bushings | Deric884 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 02-13-2010 06:53 AM |
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! | Kris@BMCPerformance | Suspension / Chassis / Brakes | 20 | 01-15-2010 09:09 PM |
Question about spoiler installation... | marley. | Cosmetics and Lighting Modification Discussions | 8 | 12-18-2009 10:27 AM |
Eibach Lowering Springs and Sway Bars Now Shipping @ BMC Performance | Kris@BMCPerformance | Suspension / Chassis / Brakes | 6 | 11-14-2009 08:34 PM |
