02-14-2012, 10:03 AM | #1 |
Drives: Race Car Join Date: Sep 2009
BMR Releases New Product: Transmission Conversion Crossmembers (TCC005, TCC030)
BMR Suspension
Modular Transmission Crossmembers for 1st Generation F-Body Swap just about any GM transmission into your 1967-1969 F-Body with a Transmission Conversion Crossmember from BMR Suspension. These modular crossmembers provide 9.75" of adjustment to accommodate Powerglide, TH350, Muncie 4 speed, TH400, TH700R4, 4L60E, T-56, TR6060, Magnum, and 4L80E transmissions. Manufactured from 1.25" diameter heavy wall tubing and ¼" laser-cut mounting plates. The BMR Transmission Conversion Crossmembers (TCC005, TCC030) provide an easy bolt-in solution for transmission upgrades, bringing today’s technology, fuel economy, and gear ratios to your classic muscle car. Includes polyurethane transmission mount and Grade 8 mounting hardware. Available in red and black hammertone powdercoat finishes. Installation time of 1-2 hours. To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055. |
02-14-2012, 09:30 PM | #2 |
Drives: hugger orange 80 camaro,needs total Join Date: Oct 2011
how much are these anyone know one crossmember does it all,i might be needing one if i decide to do a t-56 swap.i see there designed for the first generation but can they be made to work with the 79camaro.
02-15-2012, 08:45 AM | #3 |
As you know this is for the 1st generation cars but we are developing a crossmember that will work on the 2nd generation car. These crossmembers should allow you to use whatever transmission you would like. I am not sure when we will have the 2nd generation crossmembers done but it will happen. When we release them we will have them on our website and let everyone know on the forums.
02-15-2012, 09:45 AM | #4 |
thx i appreciate it,hope its soon.
02-16-2012, 09:53 AM | #5 |
Drives: 1968 Camaro, 2012 ZL1 Join Date: Nov 2011
I wish I had this when I installed my Tremec TKO. I had to loosen the rear body mounts, pry the body from the mounts and jack the trans up against the floorpan to get the Tremec mount installed.
02-16-2012, 07:06 PM | #6 |
Drives: 1969 Camaro Join Date: Jan 2011
Interesting
