Old 06-17-2014, 09:58 AM   #1
Z4me
Z4me's Avatar
Drives: 2013 ZL1 IOM Vin #169
Help Complete electrical shut down
Well Wife's civic would not start this mourning, sounded like the starter going bad. Jumped her car with the ZL1 and did manage to get it running then turned her car off and back on again to test it. Nice cloud of smoke started to appear from under the hood. Oh well i guess I will have to take her to work in the ZL1.
I moved my car back up to the drive way again, and turned it off again. Then used the key fob to open the trunk to reload the stuff back in to the car again. One problem though the electrical system went completely down and now I have no access to the trunk anymore.
I'm figuring jumping her car blew a fuse, so whats my next option to get this fixed. I mean the fuses are in the trunk right?
Yes I did positive to positive etc on the cables, the only dumb arse things I did was have my car running when I connected the cables and did not place negative cable to the frame of her car instead of the battery terminal. But in my defence when the little lady is in a rush to get to work, you tend to do dumb things .
Anyway HELP
Oh and onstar is useless when the power is gone.
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=36987&dateline=1334886195 border=0 alt= />
Z4me is offline   Reply With Quote
Old 06-17-2014, 10:16 AM   #2
HDRDTD
Anyway HELP
Well, you could jump the ZL1 with something else using the battery posts under the hood, or you should be able to fold the rear seat down to gain access to the trunk inside latch.
Old 06-17-2014, 10:19 AM   #3
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
What HDRDTD said !!
owhite3003 is offline   Reply With Quote
Old 06-17-2014, 10:48 AM   #4
BPG
Faster than you...
BPG's Avatar
Drives: 1194whp. 8.62@168. daily driver...
Fold the seat down and pull the little magic truck release handle on the trunk lid. Please do not try to run jumper cable through your car...
Pull the white thing.
GTR
BPG is offline   Reply With Quote
Old 06-17-2014, 11:11 AM   #5
Z4me
Z4me's Avatar
Thx I'm still in shock about my car, so my thought process is gone. That's why I came here to get the info, I would have evetually figured things out. My wife and I just drove the car Sunday out on the rural highway (70W) of western Maryland. Had a great time and had alot of thumbs up from other drivers. My ZL1 experianced some problems with the power steering and the power steering rack was replaced twice and in the shop for like 3 weeks. Then this happend this mourning so my brain went into meltdown mode.
Really appreciate everyone here and your help.
Old 06-17-2014, 11:15 AM   #6
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Ok I think I follow you go in from the seat run cables to the battery there and see if the car restarts again. If not then check for a blown fuse (more likely that). Just be easier if I could pop the trunk and go from the outside.
Thank you I have to go rent a car now was a rough mourning, if any one has any further thoughts i'm all ears.
You don't need to run cables into the trunk to jumpstart. There are remote terminals under the hood that you can use. In the picture below it's covered with a red cap and has a plus on it. For the ground, there is a bolt right next to your air box you can use.
Deke736 is offline   Reply With Quote
Old 06-17-2014, 11:17 AM   #7
eightup
Drives: 2013 zl1
go to sam's amd buy a jump starter runs about 60 bucks. i use mine to jump lawn mower, neighbors car, any jumping thats needed, can charge cell phone, has an air pump built in, small light to see in dark. When it gets low recharge it.
eightup is offline   Reply With Quote
Old 06-17-2014, 11:20 AM   #8
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
This
Old 06-17-2014, 11:22 AM   #9
Z4me
Z4me's Avatar
Yeah and I went to the hood first and probably looked right at it too, then remembered the battery was in the trunk. But when you have your wife late for work and her car won't start and I was half asleep I had a brain fart. But yeah your right, hopefully this might help others in the future. Thank you
Old 06-17-2014, 11:24 AM   #10
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
This. And there are more fuses in the driver side to the left of the tach side of the dash....and more under the hood. I had an electrical problem as well with everything shutting down. Scared the crap outta me. Car wouldn't start. I had to pull every single fuse, finally got the onstar to work, got every code imaginable and guess what. It was due to my LED's (when I was installing them).
Make sure your connections to your battery are good. Turn the key forward and see what you got...power or not. If no power, bad connections. There MUST be power at some point. Even with a dead battery (which is highly unlikely in this case), you'll still get a light or two on in the dash. Something's amiss. Oh...and your onstar fuse isn't in the trunk. But don't ever jump someone's car by using your battery in your trunk.
That's exactly what the terminals are for under the hood.
Old 06-17-2014, 12:03 PM   #11
Z4me
Z4me's Avatar
When I get home from work tonight, I'll start to pull the fuses one by one.
The battery should be fine, the car only has 6600 miles on it. I tried to start the car up and it's totally dead, in fact the key is stuck in the ignition! I locked the car up manually with my back up key. I just need to spend more time learning about this car (my first camaro). Oh I enjoyed the first Indy camaro fest had a great time.
Old 06-17-2014, 02:27 PM   #12
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
With no power you cannot get your key out... But there is instructions in your owners manual on how to get the key out.
The Bird is the word!
