12-20-2017, 01:11 PM | #1 |
Dyno Show Queen LOL
Drives: 16 SS & 17 ZL1 Both Yellow Join Date: Jan 2014
Modding this weekend question..
Going to install these items this weekend then drive to tuner monday..
Build List: Tony Mamo TB 918856 ATI damper 9.17 lingenfelter Supercharger Ring 15% or 18% going by certain websites. TSP Headers NGK 6510 1 heat range colder plugs Will I be ok driving it easy to tuner or should I pick up a stock pulley size for blower.. About 25 miles... shift at 2500 rpms?
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber |
12-20-2017, 01:26 PM | #2 |
Drives: Fast Join Date: Mar 2015
Do not drive it without a base tune. Shouldn’t even be started until it does. The blower is going to spin 15-18% faster and need that much more fuel, then you have the back pressure change with headers and different temp plug etc. I’d see if you can get a trailer or get the tuner to come to you or a remote tune or anything except for driving it.
12-20-2017, 04:13 PM | #3 |
Dyno Show Queen LOL
Be easier to just get a stock blower ring and similar price..
12-20-2017, 04:40 PM | #4 |
Drives: '21 ZLE A10 Join Date: May 2012
unless injectors are changed, you can drive it IMHO. You have to be very gentle and no throttle applications above “grandma”. You will get a check engine light but who cares. Call your tuner to confirm.
12-20-2017, 04:49 PM | #5 |
Drives: 2017 ZL1 Join Date: Mar 2017
My car was driven to the tuner a few miles with similar mods with no ill effect. You’ll probably be fine, just keep the rpm as low as possible and drive easy. 25 miles is quite a ways though.
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/PS4S, R888R (305/325) Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq |
12-20-2017, 05:47 PM | #6 |
Dyno Show Queen LOL
I practive today I was able to drive and shift under 1500 rpm w no problems
12-20-2017, 06:41 PM | #7 | |
Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
12-20-2017, 09:06 PM | #8 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
Yep, drive it if tuner is close (less than an hour IMO) but stay out of boost.
12-21-2017, 10:43 AM | #9 |
Drives: '03 10th Cobra Join Date: Jul 2012
What kind of HP gains do ZL1's usually get from say a mid pipe and catback switch?
12-21-2017, 10:48 AM | #10 |
12-21-2017, 12:47 PM | #11 |
12-21-2017, 04:48 PM | #12 |
Did you get an OEM replacement GM crank bolt to use? If so it doesn't fit. It will not pass through ATI hub. Just confirmed on mine.
