06-12-2023, 11:15 PM | #1 |
Drives: 2020 chevrolet camaro 2ss auto Join Date: Mar 2023
23 ss hellion tt build questions
Hello everyone,
I'd like to ask you guys before coming to a final decision. I have a 23 2ss 1le 10spd auto. I'm looking into getting the hellion twin turbo 62/62 kit. I've looked around and can't really find anything on anyone running this kit. On forums, but it was featured on PowerNation and the fitment, installation, and power results from the episode all turned me on. I want this to be a street/strip car I can drive on the weekends, around 550-600whp which is what this kit promises and delivers on the powernation episode. I reached out to the closest tuner I can find, I am located in Tuscaloosa Alabama so I don't know anyone nearby except 3 hours away in Atlanta or 8 hours away on North Carolina, so I came to these guys. They told me not to to turbos because they melt things, and tried to push the whipple kit on me because they're a dealer for them. I would prefer turbos over supercharger for efficiency reasons, looks, and sounds. Plus the whipple is very unattractive to me, the Magnuson looks much better. So my first question, do these kits melt shit? What if you use ceramic coating and heat wrap, and a turbo shield, and also spark plug wire covers? And my second question is does anyone know of a tuner that has a base map and can help dial in the fine tuning remotely for this kit? I've reached out to Hellion as well and await their response. Thanks guys, hoping to have this car on the track this year! |
06-13-2023, 04:34 AM | #2 |
Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
There is a reason why you don't see many guys running the Hellion TT kit! Yes it does melt stuff
Magnuson is a true bolt on affair with no issues to report |
06-13-2023, 07:22 AM | #3 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Jannetty Race has done one for sure maybe more. Ted would be the guy to offer you advice with your question on the twin turbo setup. Depending on what system you get they do offer high numbers 2000 HP if your engine is built for that number.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
06-13-2023, 07:39 AM | #4 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I think the Huron Speed twin turbo setup is a better fit for our cars given the extensive heat shielding needed to run the turbos up top with the Hellion setup. What’s interesting is Hellion offers a super slick mid mount package for the Mustang but not the Camaro…? So if I was going TT I’d probably do the Huron kit on a Camaro.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
06-13-2023, 01:27 PM | #5 | |
Feel free to call with any questions there have been many updates to the kit since it was first designed. We never had any problems melting things If anyone did they were not tuned correctly. https://www.facebook.com/watch/live/...55676361319091
www.jannettyracing.com
06-14-2023, 08:12 AM | #6 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
For your desired power level, I'd stick with a PD blower like the Magnuson 2650. Generally speaking, there is more work and cost to get turbos installed. You will also need a torque converter to launch it successfully at the drag strip, whereas stock converters are running deep into the 8's with 1.20 60' times.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
06-14-2023, 09:21 AM | #7 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
I wouldn't even mess with the 2650 at that power level. I would install a ported LT4 supercharger. The car will actually be quicker with the LT4 blower vs a 2650 pullied for 9psi. You don't start getting into the 2650's efficiency range until 14-15psi. You can do a LT4 supercharger just over half of what a 2650 kit costs.
You have to keep in mind that the LT1 is much higher compression. It doesn't need as much boost to make power. So the LT4 supercharger pullied for 7psi with a blend of Ethanol will make an honest 580whp. And it won't have any heat issues at that power...especially ported. It could easily be turned up down the road for 750-800whp and still be capable.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
06-14-2023, 10:17 AM | #8 | |
07-01-2023, 03:53 PM | #9 | |
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
A Few More Hellion Comments
07-01-2023, 05:54 PM | #10 | |
All said and done, a twin turbo system can be awesome for those with the knowledge, patience, and time to invest (plus $$$ lol). I know @ArmedTrashPanda has a killer twin turbo build that he recently posted up that is drool worthy (not a Hellion). But for the rest of us, slapping on a Whipple 3.0 or Maggie can make you 700-800 WHP without trying and 1K+++ WHP no problem too. It drives like OEM and can be done in a weekend. Tough to beat.
07-02-2023, 08:57 AM | #11 | |
I have sold and remotely supported several others that have also had great results. In My opinion it is the cost and skill set required to do this correctly that deters many, seems most want to take the easy route which is somewhat understandable. These systems are Top notch and combined with professional installation give stellar results boost for boost. There is no debating turbos make more power Per LB of boost than any other option. The system has the potential to make outrageous power but not without the fuel system upgrades which add another 2.5-3K to the project. If there are any questions I can answer don't hesitate to reach out. Ted.
07-06-2023, 07:45 AM | #12 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
i have a hellion twin system and the installation was extensive. but to be honest i would never use another power adder besides turbo; so it was the right way to go for me.
the pita of the install is you have to cut and move and alter electrical stuff and other components that would have to be replaced later if you were to go back to stock; which sucks. the power supersedes all the bs tho.
07-07-2023, 07:25 AM | #13 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I know several guys with pd builds and have been around a couple of turbo builds, on other platforms. I wouldn't hesitate to take any of the pd cars on a cross country road trip. I wouldn't dream of trying it in any of the turbo cars. OP, unless you have Hitmix300 or Parish8 level skills, tools, etc. I would not attempt a turbo build. If you're lucky, you may not have any major issues, but you WILL be working on something almost constantly. This is fine if you enjoy working on cars, and have the necessary skills, tools, and equipment. If not, your car will likely spend as much time at the shop as it does on the road
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned |
07-07-2023, 07:49 AM | #14 |
The biggest Killer for Turbo systems is installation techniques and experience.
When done by qualified professionals there are no problems we proved this time and time again. Ted.
Tags |
hellion, turbo |
