06-11-2017, 08:01 AM | #1 |
MUFFLER QUESTION.
Hey there Camaro family, those of you who have done the quad tip install and are running mufflers behind them, what kind are you using if so, and do you have any pics of the setup.
Thanks all.
06-12-2017, 12:13 PM | #2 |
Bump,,, anybody ??? Thanks. Can't believe everyone is straight piped behind the tips...Thanks
06-12-2017, 12:33 PM | #3 |
Drives: 2011 2SS Join Date: Mar 2015
What kind of mufflers? I'm using flowmaster outlaws. I'm sure if you take your car to any exhaust shop, they'd be able to make quad tips work on your exhaust
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3 pipe to NPP mufflers, 3.91 gears |
06-12-2017, 07:58 PM | #4 | |
1 shop I went to so far with 4 different muffler configurations and they said it just would not work due to the mufflers being too long to fit in with the tips. I am looking at the Dynomax Ultraflow round mufflers 4 inch diameter that the case is only 14 inches long, found a pic on the web showing my tips, the SS Clone ones attached to them, so that should work. Just want my quad tips back on. With a little quiet rumbly exhaust that screams at WOT like it does now.
06-12-2017, 08:00 PM | #5 |
Wow that's frustrating..
2011 SS L99
06-13-2017, 12:34 AM | #6 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
You're telling me they cant get SS clones to work on these? I understand sometimes the bend can be an issue if it's too close but these stick out a reasonable amount assuming I have the right mufflers pictured below. If they are it sounds like you need to find a better area to start asking
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
06-13-2017, 06:20 AM | #7 | |
06-13-2017, 07:23 AM | #8 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
I installed quad tips myself on two different catbacks that ive used and had a similar problem when I had some bullet magnaflows on. What I did was cut almost all the way but not completely behind the muffler so that the gap would let the pipe bend towards the inside so that the end of the exhaust would be centered on the opening and then I welded up the part that I cut. At that point the opening at the end of the exhaust was at an angle facing the inside so then I welded the tips to the exhaust in an angle so that they appeared to be straight and centered. Its a bit complicated and I know its a little hard to understand the way I explained it but if I was able to figure it out then an expert on these stuff should have no problem doing it. Keep looking for other shops and eventually someone will be able to do it
06-13-2017, 07:29 PM | #9 | |
06-13-2017, 07:42 PM | #10 | |
