Old 10-18-2017, 09:08 AM   #1
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
What compression ratio are you running? looking to rebuild.
So far the two shops I contacted want to rebuild my or replace my engine with a 417 CI and drop the compression to 9.1.
I really love the sound of high compression at idle. I also am totally happy with what I have now. Is there any real reason why I cant just get my same 6.2L set up but in a forged version. Or is dropping the compression necessary.
I plan on tracking the car. Maybe 1 or 2 times a year.
Pollock is offline   Reply With Quote
Old 10-18-2017, 09:29 AM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Forged LSA 416 10.5 cr...
Ported LSA blower, 2.45 upper, 9.17 lower, 13.5 PSI boost, E85
-Don
747 RWHP 794 RWTQ
Old 10-18-2017, 02:18 PM   #3
MoeIv
MoeIv's Avatar
Drives: IOM 2SS/RS
Iron 370 9.5:1 cr
twin turbo pte 6766
MoeIv is offline   Reply With Quote
Old 10-18-2017, 02:54 PM   #4
CGbambam
Drives: 2011 Camaro 2SS
I'd do high compression
only reason id advice against it is if you don't want to run 93/meth/e85
I'm running twins on 11.1 compression no problem
CGbambam is offline   Reply With Quote
Old 10-18-2017, 02:57 PM   #5
Pollock
LT4 M6
Pollock's Avatar
I was planning on sticking with 93 octane.
Old 10-18-2017, 03:13 PM   #6
CGbambam
depending on how much boost you want to run you'd might need some meth, you might ping without it
Old 10-18-2017, 04:26 PM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
10.5:1 with iron block, E85 and meth
Old 10-18-2017, 06:33 PM   #8
Pollock
LT4 M6
Pollock's Avatar
I will be happy with 8 psi.
Old 10-18-2017, 07:53 PM   #9
ecreps
Drives: 2014 1LE, 1996 z28
10.25:1
ecreps is offline   Reply With Quote
Old 10-18-2017, 08:24 PM   #10
cc-rider
Drives: 2010 Camaro SS
If you’re not going E85...stay in the 9-10:1 range. If you are going to do E85...then you’d be smart to be in the 10.5-11:1 range.
There’s a good highly technical article out there somewhere that explores what’s better...more compression and lower boost...or lower compression and higher boost. The conclusion of it is that your always better lowering compression and turning up the boost. Some argue that’s old school and that these new engines and heads are so efficient that you can up the compression. But most people also want E85 too.
Fun topic to research. Tough to answer. I’m contemplating the same thing.
cc-rider is offline   Reply With Quote
Old 10-19-2017, 09:25 AM   #11
CGbambam
So let me get this right you're running a stock 6.2 stock compression on 8 psi with a maggy right now?
Old 10-19-2017, 10:07 AM   #12
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
LOL, famous last words!
RealQuick is offline   Reply With Quote
Old 10-19-2017, 02:33 PM   #13
hou30guy
Drives: 2011 convertible 2ss/rs
408 stroker 10 rib supercharged maggie at 10.1
hou30guy is offline   Reply With Quote
Old 10-19-2017, 07:23 PM   #14
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Forged LS3 10:1
SLP Supercharger 12lbs
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
