04-06-2022, 12:09 PM | #1 |
Drives: 2013 Caprice PPV 2014 Caprice PPV Join Date: Mar 2022
Weight Distribution Camaro5
Using the scale at the local quarry/stone crusher, my 2010 Camaro (rounding off) comes out as 52 front-48 rear. That's a significant improvement over the Camaro6 which usually comes out as 55 front-45 rear. Gas/driver variable is why I round off. The Cadillac 2011 CTS (Alpha not Zeta platform) is close to the 2010 Camaro5 and my 04 GTO is almost identical to the Camaro6. Both the G8 and Chevy SS published numbers are close to 52/48. I don't own either to weigh.
04-06-2022, 01:52 PM | #2 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
im thinking a 6 cylinder would be pretty close to 50/50 then,engine and trans would be lighter.
04-06-2022, 02:13 PM | #3 |
Delta for the V-6 vs V-8 is 110 -115 pounds. 6L80E for both not so different. My LSX is built off a 5.3 block which is 110 pounds less than 6.0 or 6.2 block. With the V-6 or the LSX, ~50/50 weight distribution for a Camaro5 but not a Camaro6. If OEM a V-6 Camaro5 is ~ 50/50 and GM always inclines its cars toward understeer (except some Corvettes), the OEM rear sway bar for a V-8 would be a move toward a neutral handling car.
04-06-2022, 04:20 PM | #4 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Are you comparing 5.3 aluminum to 6.2 iron block?
04-06-2022, 04:35 PM | #5 |
Look it up. Aluminum V-6 Camaro5 engine 345 pounds
Aluminum V-8 Camaro5 engine 460 pounds Do the math |
04-06-2022, 05:51 PM | #6 | |
Drives: ABM #93 Join Date: Oct 2018
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
04-06-2022, 06:21 PM | #7 |
The 2010 Camaro aluminum V-6 weighs 345 pounds and the aluminum 6.2 L
V-8 weighs 460 pounds according to multiple sources. My LSX from The Hot Rod Company of Green Acres, Washington, USA was built on the 5.3 block and its shipping weight was 396 pounds, including the wood frame it travelled in. |
04-06-2022, 06:22 PM | #8 |
im pretty sure he is comparing the 3.6 to the 6.2.although he mentions that his engine is a non stock 5.3.
04-06-2022, 06:30 PM | #9 |
That 460lbs is a pretty much decked out engine with at least some of the accessories if not most. The Aqua Blue it’s basically the same block and similar internals. And I guess I really should have asked about the iron block 6.0 but I really don’t pay that much attention to the iron block stuff.
04-06-2022, 07:39 PM | #10 |
Not dressed
As I stated:
My LSX from The Hot Rod Company of Green Acres, Washington, USA was built on the 5.3 block and its shipping weight was 396 pounds, including the wood frame it travelled in. Shipped to Zurich, Switzerland, they made sure they got the weight right. Obviously not full dressed, and I wasn't expecting air conditioning components, though it did have the belt/pulley system. |
04-06-2022, 07:46 PM | #11 |
Everything I can find says the block weights for the LS3 and any of the 5.3 aluminum blocks are virtually the same so the in the car weight will be the same. Of course if the Hot Rod Shop milled the block to remove weight it could be lighter. Not sure I would want that motor though if it was a significant weight.
I’m now bowing out again before this discussion annoys everyone again. |
04-06-2022, 07:49 PM | #12 |
Wise as discretion is the better part of valor.
04-07-2022, 03:57 AM | #13 | |
Engine machining and CNC data from The Hot Rod Company (not shop) You'll see they are proud of their international shipping. Their shipping weight is a fact for economic reasons vital to their business. |
