04-03-2014, 10:27 AM | #1 |
ZL1 crystal RED
Drives: ZL1 2014 Join Date: Oct 2013
Pulley 2.55 ZL1 ?
Hi guys,
I want install a 2,55 pulley on my ZL1's supercharger. Have you done this stuff? Is it necessary to machine the part around pulley axle? Thank you for yours answers
04-03-2014, 11:20 AM | #2 |
Drives: 2013 ZL1 Ashen Gray Join Date: Oct 2013
You don't have to machine for a 2.55 but you do have to remove the front of the SC called the snout.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 |
04-03-2014, 12:06 PM | #3 |
Drives: 2013 ZL1, 2016 Denali HD Join Date: Jun 2013
+1
LSX 427, Twin Precision Turbo's, 64/66. Nitrous Outlet System. Pro EFI Engine Management Systems. Vengeance Racing Built......
04-03-2014, 01:13 PM | #4 |
Drives: Camaro 2SS 2012 Join Date: Nov 2013
The snout is the support of pulley axle. isn't it?
How can I remove it? Have you a picture of your installation? Thank you!
04-03-2014, 01:16 PM | #5 |
I didn't take any when I did mine but if you search blower reassembly you will see all the video you will need to disassemble and reassemble the SC.
04-03-2014, 03:13 PM | #6 |
Thank you, Baer383!
I saw many videos and they machine the snout because the pulley has a very little diameter. Can you take a pic of your SC now? Thank you!
04-03-2014, 03:16 PM | #7 |
I'm at work and the car is at home ,and I put Lingenfelter 2.55 pulley on mine and it has plenty of room but if you put the 2.38 from LPE then you will have to machine the snout.
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 Last edited by Baer383; 08-24-2014 at 04:18 PM. |
04-03-2014, 04:19 PM | #8 |
OK, thank you.
Here is the night. While you work, we sleep
04-04-2014, 11:08 AM | #9 |
ZL1 crystal RED
No machining, perfect, thank you
04-04-2014, 06:23 PM | #10 |
Adm performance sells the 2.5 pulley with the hub that presses on. Works great. No machining required. Only the 2.38 requires the snout to be machined for clearance.
04-05-2014, 12:37 PM | #11 |
ZL1 crystal RED
Thank you
01-13-2016, 01:59 PM | #12 |
ZL1 crystal RED
Pulley of origin goes out has the press?
Pulley 2,55 has the place
01-18-2016, 01:54 AM | #13 |
ZL1 crystal RED
Pulley 2,55, OK . To put pulley origin, possible on support 2,55?
