Old 02-09-2017, 04:36 PM   #1
ARrado15
Drives: 2011 Camaro 2SS
Should I upgrade pump/thermostat?
So I'm swapping my cam next weekend, and just found out that you need to remove the oil pump to get the LS2 dampener in. I was against swapping the stock one because I didn't want to touch it, but now that I have to I'm starting to consider replacing it. Is it really worth the $150 for the melling? Would you suggest the High Volume, High pressure, or the TSP oil pump if you were to change it? It's an LS3 btw...
Also, would you guys bother changing the thermostat to a cooler one while your already in there? I have heard mixed reviews on the thermostats and how it can actually damage your motor....
ARrado15 is offline   Reply With Quote
Old 02-09-2017, 05:07 PM   #2
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
I just ordered my cam kit, I went with the melling. There are plenty of threads about the stock ones failing and causing hell. Might as well do it as cheap added insurance and peace of mind. As for the thermostat, I decided to leave mine alone. There seems to be more evidence on keeping the stock one on NA engines than there is to swap it out.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 02-10-2017, 06:09 AM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
get a Melling pump. the 10295 is all you need the hi volume 10296 is fine too.
JCunningham is offline   Reply With Quote
Old 02-13-2017, 10:25 AM   #4
ARrado15
Ordered the 10296.
Old 02-13-2017, 11:58 AM   #5
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Yes good work on ordering the Melling....2010 and 2011 Camaros had issues with the stock oil pump seizing open....happened to me with 14,000 on my 2011.
i have a the Melling Pump in now
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 02-13-2017, 12:42 PM   #6
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
Should the oil pump on the 11/12's be changed only when upgrading the engine or is it defective otherwise stock? Was there a recall?
rich2342 is offline   Reply With Quote
Old 02-13-2017, 01:37 PM   #7
ARrado15
I've heard that they can have the relief valve stick and cause a complete loss in oil pressure. I figured it's only 150 bucks for peace of mind
Old 02-13-2017, 02:56 PM   #8
arussh
arussh's Avatar
Drives: 2011 2ss/rs, 1990 iroc-z
i considered a melling then just ported the stock one to remove some material to eliminate the possiblity of oil cavitation. That seems to be the issue with stock pump.
30 minutes of porting fixed that. Side bonus is that oil pressure is a bit stronger cuz flow is more direct now.
arussh is offline   Reply With Quote
Old 02-13-2017, 03:26 PM   #9
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
On the LS3, definitely replace the pump...The more aggressive cam plus hot days and the stocker will fail. Replace all seals/gaskets while you're in there and upgrade timing chain too!
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 02-13-2017, 07:45 PM   #10
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Its been defective on completely stock cars and highly modified. A lot of 10s-11s don't ever have this issue...but there are quite a few posting on this forum that had the valve stick open.
Thankfully these cars have a warning system and will alert you that there is no pressure and to turn the car off immediately, which eliminates any motor damage. I would only worry about it if it happens. If your doing internal work done on your exsisting LS3 than yea change it out.
