Old 03-14-2017, 02:28 PM   #1
FLcamaroSS
FLcamaroSS's Avatar
Drives: 2013 Camaro 2ss
Engine light on after Cai install
it makes sense that the engine light comes on after you install a mod to the engine, (I'm guessing) but how to get the light reset on the Camaro?
FLcamaroSS is offline   Reply With Quote
Old 03-14-2017, 02:41 PM   #2
Mac Arnold
Drives: 2011 Camaro 2SS/RS
Disconnect the negative battery cable for a few minutes that should take care of it.
Mac Arnold is offline   Reply With Quote
Old 03-14-2017, 03:09 PM   #3
Welker2
Ret AF, cancer survivor
Welker2's Avatar
This ^^^^
Old 03-14-2017, 03:45 PM   #4
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Make sure that it's not the mass air meter reading incorrectly. Otherwise you will have to purchase one that can handle the increase of airflow
Coz3z3 is offline   Reply With Quote
Old 03-14-2017, 05:42 PM   #5
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Both of these. Read the code before resetting it!
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 03-14-2017, 06:19 PM   #6
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Also clean your MAF sensor .
BIO-HAZARD is offline   Reply With Quote
Old 03-14-2017, 08:45 PM   #7
FLcamaroSS
FLcamaroSS's Avatar
code on the MAf was k11
I read as long as the code was a letter followed by a number it should be good,no?
Old 03-14-2017, 11:10 PM   #8
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
He means to get an engine code so we can get a better idea of what is setting off your engine light
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 03-15-2017, 01:36 AM   #9
MrChrisLS3
Drives: 2018 1SS M6
code should point to the issue. I'm betting it will be a maf sensor code. First, is to make sure it was re-installed correctly, they are directional.
Second would be, if the filter is oiled, that there wasn't too much oil on the filter. This can cause the maf to set the CEL.
Third is to double check the install of the kit. Make certain everything is good and air tight.
MrChrisLS3 is offline   Reply With Quote
Old 03-15-2017, 01:46 AM   #10
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Which CAI did you put on???
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 03-15-2017, 03:53 AM   #11
Gunmetal Speedster
That would mean it's a strong MAF sensor which is a good thing, means it should handle the increased flow just fine!
Bubba is right as to what I was referencing. The code that is being thrown may not have anything to do with it being weak or strong so checking to see what code is being thrown can give us a better idea as to why it is coming on.
Chris hits the last bit on the head.
If you have a strong one (which it seems you do) airflow shouldn't be a concern. I would recheck everything and make sure it's all hooked up and connected right. Make sure connections are tight and that the MAF is indeed inserted the right direction. While checking those, try and see if maybe the filter was over oiled? Assuming you used one that wasnt a dry filter. If you think this may be the issue, try removing it and cleaning it carefully with MAF cleaner and letting it sit and dry for a good bit. If that's not an issue or you've done that already, the last thing would be to check the code that is being associated with the CEL if there is still one. If you don't have a code reader, your local Autozone or O'Reillys should be able to check it for you for free. Report back here with that code if that's what it comes to and we will take it from there haha. If not, then you're good to go Which intake did you end up going with?
Old 03-15-2017, 04:03 PM   #12
FLcamaroSS
FLcamaroSS's Avatar
I put in the K&n typhoon. Thanks for all the input. I'll head up to autozone and try and get an answer on the code.
Old 03-16-2017, 12:34 PM   #13
FLcamaroSS
FLcamaroSS's Avatar
so the code is p0443, evap purge control valve. is that something that gets changed due to the aftermarket intake?
Old 03-16-2017, 01:11 PM   #14
BillGalina
BillGalina's Avatar
Drives: 2014 Camaro 2SS/RS Crystal Red Tint
try checking your gas cap make sure it is there and tight
Mods: V Max TB/ American Thunder Catback/ Granatelli Wires/ CAI/Catch Can,Stainless Power Headers/JRE Tune
BillGalina is offline   Reply With Quote
