Old 03-24-2017, 12:41 PM   #1
ARrado15
Drives: 2011 Camaro 2SS
Tune changing idle tone?
It might just be me but after installing my cam the car had a really nice chop to it, until I got it tuned. It seems like it was smoothed out a lot to sound almost stock until I hit the A/C... I'm just curious as to if a tune can actually change the "sound" by adjusting different parameters or if it is just me...
2011 Camaro SS - Kooks 1 7/8" LTH - Kooks HFC - Solo Mach XL Catback - CAI Intake - VMAX TB - Howards ASA Cam
ARrado15 is offline   Reply With Quote
Old 03-24-2017, 01:12 PM   #2
Spitfil2e
Spitfil2e's Avatar
Drives: 2011 Camaro 1SS Victory Red
I wouldnt say it changes "tone" I know different tuners tune the idle at different rpms, this can have that effect, If you want the rough idle back tell him to set the idle lower.
2011 LS3 M6 Rotofab CAI, Comp Custom Grind Cam 224 / 234 @ .050, .581/.576 w/ 1.7 rocker, 114 lobe sep 110 int c/l, Borla Full Exhaust, Ridetech Stage 2 Coilovers, McLeod RXT Street Twin Clutch, JPSS front and rear sway bars, JPSS caster locks, Forgeline GA3R Wheels Victory Red inner and outer barrels and matte back Spokes wrapped in Bridgestone 305 re71r on all four corners, Other JPSS Stuff. 455RWHP and 411RWTQ on Nascar Dyno.
Spitfil2e is offline   Reply With Quote
Old 03-24-2017, 02:21 PM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
Absolutely it can. Specifically, the Idle Adaptive Spark control Overspeed and Underspeed. You can add or subtract the amount of spark advance, so that the idle chops. You could do it with the stock cam if you wanted.
Download the HPTuners demo version and check it out.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-24-2017, 03:06 PM   #4
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Your idle was increased by about 100-150 rpm in the tune for the cam.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 03-24-2017, 03:56 PM   #5
Bo White
Bo White's Avatar
A tune will definately change it.
Old 03-24-2017, 04:41 PM   #6
eLeSthree
The first tune has a large swing from under to over spark. So the car would have a big choppy sound.
The second has less variation from over to under, so the swing in spark timing is tighter. This is the tune I have on my car. The chop sound is still there, but not as much. I find this tune to have better idle. My idle is set at 750.
I'm sure there are more fields in the tune that contribute to the chop sound, but these are the most popular I've found on the tuning forums.
1158whp 1017wtq.
630whp 658wtq
Old 03-25-2017, 12:36 PM   #7
ARrado15
I'm assuming you need to purchase the hptuners "programmer" to pull a tune file just to check it against the software?
Old 03-25-2017, 02:14 PM   #8
eLeSthree
You do need the hardware to pull the tune file, but it doesnt require licensing to pull and view the file, but you cant make changes. If you know someone with hp tuners they could pull it for you. Ask your tuner to email you the file.
1158whp 1017wtq.
630whp 658wtq
