Old 03-26-2017, 07:16 PM   #1
trans665
trans665's Avatar
Drives: 2013 2ss
Oil pressure problem.. Help
Just to let you know this is going to be long. Okay I need help. I installed a 6.0 iron block ly6 engine into my Camaro. Starts up fine everything is good ...but my oil pressure.. starts off in about 30 PSI and then drops as you pick up RPMs. So I went ahead and put a Milling oil pump in. And after all that it's still doing the same thing. I even went and got a new oil pressure sensor period and still it cranks up at 30 PSI sometimes lower period and when you go around the block and you pick up RPMs the pressure drops. When I got the Block in I inspected the bearings and they were good. So it can't be because of the crank. I am open to any ideas thank you for your time... because I am out of ideas unless oil pump I installed was a piece of s***
2013 auto ss..full bmr suspension..3800 stall...s475 turbocharger on 16 psi with 150 nitrous outlet plate...,BTR stage 3 turbo cam.....100% Methanol injection....LY6 6.0 iorn block ...
trans665 is offline   Reply With Quote
Old 03-26-2017, 07:23 PM   #2
trans665
trans665's Avatar
Drives: 2013 2ss
Is 5-40 to thin of oil??... people are telling me to put thicker oil by thought this was thick enough
Old 03-26-2017, 09:15 PM   #3
BAD IDEA
Drives: 2010 Camaro SS RS
Check true oil level in the pan sense you changed the block. Did you keep the same pickup tube? Is there oil scrapers installed. Sounds like it's starving for oil at higher rpms. Also check where does the pick up tube screen sit in relation with the bottom of the pan, should be close ( 3/4") to the bottom. Also did you replace the "O" ring when you replaced the pump?
BAD IDEA is offline   Reply With Quote
Old 03-27-2017, 12:29 AM   #4
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
is your engine a rebuild? 5w30 is all you need unless the engine was clearanced for thicker oil. Have you put a real oil pressure gauge on it?
JCunningham is offline   Reply With Quote
Old 03-27-2017, 09:32 AM   #5
trans665
trans665's Avatar
Drives: 2013 2ss
Everything on the engine besides the block is LS3. The pickup tube and oil pan is off LS3. I change the O-ring for the pickup tube with the new melling oil pump. I change out the oil pressure sensor and I checked for any blockage. Right now I'm using 5 w40 Oil. And as far as oil level goes on my dipstick it says it's perfect I don't know if that would matter since I'm using a LS3 oil pan and pick up tube? Somebody told me that in the oil pan that part that sticks up. That I need to replace it it looks like it's on top of the oil filter and it goes straight up into the block. But I'm not too sure about that.
Old 03-27-2017, 09:35 AM   #6
trans665
trans665's Avatar
Drives: 2013 2ss
I also had VVT delete kit from the LS3 I transfer to the 6.0. I'm really stumped I'm going to tear everything apart. And start from bottom to top. I just don't see what went wrong. I don't understand why it would start off at 30 PSI and get to higher RPMs and go to 0 after I change the oil pump and the pressure sensor. I cleaned out the pick up tube before I reinstalled... unless there was something inside the block that fell to the oil pan and is restricting my pick up tube.... because this is a fresh build. Everything I put onto the block was clean and had no debris.
Old 03-27-2017, 09:51 AM   #7
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Which oil filter are you using?
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 03-27-2017, 10:00 AM   #8
trans665
trans665's Avatar
Drives: 2013 2ss
Fram gold
Old 03-27-2017, 10:01 AM   #9
trans665
trans665's Avatar
Drives: 2013 2ss
One more thing I went ahead and blocked off the oil cooler but cuz I read people's done it but would that affect anything
Old 03-27-2017, 01:56 PM   #10
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Try Wix and see if that solves it...Worth a shot
Old 03-29-2017, 09:55 AM   #11
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Two things. The front plug is missing or the rear plunger is missing/installed wrong.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 03-30-2017, 02:36 PM   #12
trans665
trans665's Avatar
Drives: 2013 2ss
I found the problem a couple days ago sorry for the late response. I'm not a Certified mechanic and I make mistakes period so that being said. I'm going to sound like an idiot. When I did the block off plate I did not research it I just deleted the oil cooler and I made my own. So instead of having circulation there it was blocked off..
Old 03-30-2017, 02:37 PM   #13
trans665
trans665's Avatar
Drives: 2013 2ss
With the million 10335 oil pump. I'm at 65 PSI at idle all the time and up to about 75 PSI so now I have what some people are telling me perfect oil pressure I just need to get a oil reducer for my turbo inlet
Old 03-30-2017, 07:52 PM   #14
2010_camaro
I had the same pressure. My turbos are journal bearing and I don't have oil restrictors. My feed lines are -4 and my return is -10
