Caryle Racing
Old 08-11-2010, 08:29 PM   #1
jrpxxii
jrpxxii's Avatar
Whats the best clutch for 1000+ HP?
I am going to convert my manual M6 over to an automatic but until then I need a clutch that will hold up to 1000+hp to the rear wheels. I have read that the LS9 everyone is happy with but I think it is only rated to 700hp and I have the Fidanza 7.6 installed now but not really happy with it as it squeals and chatters like crazy.
Old 08-11-2010, 10:00 PM   #2
thekid96
Drives: Z06, 69 Camaro
RPS triple if you intend to beat on it and have it live. I have also been running the Ram dual disk puck unit for a while. It will hold the power at the track but it chatters, stiff and on/off. It has a very defined friction point, though, so it is great to launch with lots of feel and feedback.
thekid96 is offline   Reply With Quote
Old 08-11-2010, 10:09 PM   #3
jrpxxii
jrpxxii's Avatar
The Fidanza holds up but its halfway embarassing to drive in town and leave a stop light and it squeal everytime. It didnt do it right off as I broke it in for awhile but now its wore in some once it gets some heat it is just annoying. I may just keep it until I do the swap anyways.
Old 08-11-2010, 11:08 PM   #4
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
I just went through a fidanza at the track with only 640 rwhp!!!
Pictures of toasted fidanza on Cincy Speed Facebook page.
I ordered an ls9 clutch just now.
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 08-12-2010, 05:14 AM   #5
Mcnhammer
mcnhammer
Mcnhammer's Avatar
Drives: 2010 Cyber grey Camaro SS
Clutch good for 900 ft.lb.torque
I've been running a Mcleod RXT twin disc. cost is some what high at $1130.00. I decided to go with a steel flywheel as the car is some what heavy at 3860 lbs. I've had good luck and I'm pushing 582 rwhp. Just thought I'd though this out.
Mcnhammer is offline   Reply With Quote
Old 08-12-2010, 11:57 AM   #6
jrpxxii
jrpxxii's Avatar
Andrew I saw those pics but I just thought it was the stock clutch. I really dont think there is a clutch out there that is going to handle my power level as Im pretty sure the TR6060 isnt capable. I am just going to kill the Fidanza I have it and get a custom built
4l80e and do the swap so I can actually use the power that the new build is going to offer.
Old 08-12-2010, 07:46 PM   #7
GFORCE1320
Drives: 05 GTO
I can get you into one of the new Monster Twin disk's that we did the design work on.
Will hold way more then 1000hp, doesnt chatter and is as smooth as a babies behind
Give me a call Jason.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 11:51 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
