| Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications. |
Thread Tools |
#126 |
Rollin' Green
Drives: 2010 Synergy Green Camaro Join Date: Dec 2010
I'm having a problem with the passenger side halo, too. Checked the splices, and they look good. I'm going to try restripping the wire and resplicing and checking the connection at the bulb this weekend. Not sure what else to try after that.
But it is kind of strange that everybody who has a problem is on the passenger side... of course it could be coincidence.
#127 |
Quick Photos
Here's a couple photos of my Eagle Eyes. Note that I took the wheels off and the wheel wells for easy access to the fascia bolts. Love the Eagle Eyes and HIDs.
SS2 Black with CGM Stripes 3800 Born: 25 May VIN#12136 6000 Mine 26 June 2009 ![]() SLP Loudmouth II, NOWEEDS, BMR 1.4/1.0 Lowering Springs, Cold Air Inductions Intake, Tune, Eagle Eyes w HID, SLP "SS" Grille Insert, Pistol Grip Shifter, Hawk PC Pads, RGB Scanner, Tint, Headlight Armor, Clear Bra, 22's. |
#128 |
Mark it ZERO!
Looks great Vince!
#129 |
![]() ![]() Drives: 2010 Camaro LS Join Date: Mar 2010
got my Eagle Eyes & HID kit yesterday...installed the HIDs into the headlights this evening...all is ready for a Sunday install...I've been taking lots of pics & plan on writing up a detailed DIY when I'm done
#130 |
God Bless Dawson
Drives: Synergy for my Daughter Join Date: Feb 2010
They look good with the HID.... not so much with just halogen. I wonder what type light is used to light the halo. Might be able to make it a different color.
![]() I still prefer the retro look. Not a european look fan.
#131 |
H3LL1ON
Drives: 2010 1LT Camaro Synergy Green Join Date: Jul 2010
The Eagle Eyes halo is a CCFL type, containing gas/ chemical in glass/plastic tube. There is no way to alter color as far as I know.
It's Green, really Green!
C5![]() |
#132 | |
x7productions.com
Drives: 2010 BMW E92 3-Series Coupe Join Date: Jan 2010
Watch Camaro : Heritage - Featuring over ten Camaro5 Members' 2010/2011 Camaros!
http://www.camaro5.com/forums/showthread.php?t=158574 Go like our Facebook Fan Page! http://facebook.com/x7productions/ |
#133 | ||
كمارو صفرا ^_^
Drives: '10 Camaro LS - M6 Join Date: Mar 2010
#134 |
Banned
AMAZINGLIGHTS!
#135 |
Banned
i have a question. okay i got my headlights and all but i was wondering. the stock bulbs has like 3 wires and all that. when u remove the stock bulb to put the hids. dont you have to take off the cables too? i know the factory harness is attach to that too? so can you please explain me how to convert to HIDS?
like a DIY Eagle eye Halogen Converter to HIDS. |
#136 |
H3LL1ON
I bought the HID kit from VME.
So you put your hid bulb in the EE socket like normal. The 2 pin EE bulb connector is where the 2 spade connectors{black/red} shown in the picture go. Then on the hid harness the power supply 2 pin connector goes in the ballast. The other 2 single wire hid plugs coming from the hid bulb connect together to the hid harness. Last the EE 3 pin plug{blue/black/white} connects to your factory headlight plug. Hope that helps.
C5![]() |
#137 | |
كمارو صفرا ^_^
#138 | |
#139 |
![]() Drives: 2010 Camaro LS Join Date: Jan 2011
I got a qeustion I just got my eagle eys not installed yet but on the back of them is shows h9/h13 whats that mean its uses both or any ideas thanks
Anything under 200Km/Hr your just another Sunday driver
#140 |
It means it uses H9 bulbs but it has a connection converter that allows it to hook up to the factory H13 harness on the Camaro itself.
#141 |
![]() Drives: 2010 SS - LS3 - CGM Join Date: Oct 2010
So I'm going to be pulling the trigger on these soon. If they're wired to the parking lights, do the halos stay on while driving?
![]() Injen Long-tube CAI, Flowmaster American Thunder Catback, Eagle Eye Headlights w/HIDs, Sparks SS emblems, Unrestricted Motorsports Gen1 Spoiler, Vossen CV3 Wheels, Nitto Invos (275/40-20)x4 |
#142 |
ok, here is the DIY for the adding the HID kit to these
http://www.camaro5.com/forums/showth...=1#post2813923
#143 | |||
#144 |
Sounds perfect, thanks for the response man!
#145 |
Banned
Well!!!! HIDS are installed i went 8K...
at first i got worried because i thought high beams wasnt working..all i heard was clunk sound...i was like...mm maybe something is blocking it...comes to be...its like that!!! easy to install hids! i didnt know you didnt have to unscrew the back plate...so i stripped one screw..owells
#146 |
Banned
how do ya like so far?
#147 |
Banned
question do we need to run a relay system or not? i have one but from my old setup..h13 bixenon. would it work. i have all the plugs pluged in just need the factory harness and they work
hi n lows but is a relay needed?
#148 |
Banned
look
![]() Red Squares are to the ballast Greenish Square is to the power Orange square is to the Grounder but the Red Circle is to??? its a 2 prong typish connector? the cable just sitting in the middle was used in the H13 Bi xenon kit and im guessing not to be used in this install? help please? |
#149 |
Banned
and this is how i have it setup in the garage right now..
![]() all that it is missing is the factory connector which is in the car! lmaoo. would it be good to run it like that ? i mean...it will not have a relay but would it be bad? also would my relay work as posted earlier ? and if i do go relay. where would the wires that are connected from the hids in the headlight that go to the ballast go? |
#150 |
H3LL1ON
Does the wiring diagram showing the optional relay setup that I posted above not help?
C5![]() |
| Thread Tools | |
| new eagle eye halo headlights | tallmantony | Cosmetics and Lighting Modification Discussions | 51 | 01-29-2012 09:11 PM |
| OEM Non-RS Headlights with AAC Halo's & HID's | erk5000 | Exterior Parts & Accessories | 11 | 08-06-2010 05:42 AM |
| Did anyone change non-rs headlights to OEM RS HIDs (bi-xenon) | verboten | Cosmetics and Lighting Modification Discussions | 8 | 06-14-2010 12:43 PM |
| I can see! | The_Blur | Off-topic Discussions | 31 | 07-01-2009 02:19 AM |
| "Regular" headlights (not HIDs) | 2KZ28_For_Now | Camaro Photos | Spyshots | Video | Media Gallery | 66 | 11-14-2008 07:07 AM |
