Old 11-26-2008, 10:51 AM   #1
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
Will the SS have 20" run flat tires? Can we go bigger in size?
I understand we don't have a spare tire with the Camaro SS, will the furnished tire be the run flat type.
Can we use a wider tire in 20" size?
Hoss is offline   Reply With Quote
Old 11-26-2008, 12:35 PM   #2
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
No, there will not be run-flat tires on the SS.
rolnslo is offline   Reply With Quote
Old 11-26-2008, 01:44 PM   #3
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Old 11-26-2008, 03:24 PM   #4
Hoss
Hoss's Avatar
Does anyone make a good run flat set of tires for thr Camaro SS?
Old 11-26-2008, 05:27 PM   #5
Rallyman6
Member
Rallyman6's Avatar
Drives: '10 2SS/RS IOM, Wht Stripes, Roof
We'll get a can of fix-a-flat with the car.
Think of the weight savings... no spare
Here are some good run-flats
2SS/RS IOM, Wht Stripes, 6MT, IO Interior, Roof, Eibach Sways, BC Coilovers, BMR Swing arms,Barton Short Shift, BBK LT's, GMPP exhaust, Hi-Flow Cats, MAST Stage 2 Cam, CAI = 470RWHP
Rallyman6 is offline   Reply With Quote
Old 11-26-2008, 06:41 PM   #6
JJ#48Racing
Drives: 1998 Camaro SS
I know the Camaro SS doesn't come with a spare, so it doesn't make sense to me that GM would give us non-runflat tires.
JJ#48Racing is offline   Reply With Quote
Old 11-28-2008, 02:45 AM   #7
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
sure a can of tire filler will work for small holes, but what if you have a bigger hole?
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 11-28-2008, 04:24 AM   #8
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
Spare tire is available as an option.
camaro5 is offline   Reply With Quote
Old 11-28-2008, 04:38 AM   #9
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Last I checked, not for the 2SS. I think they should be run flats too.
Old 11-28-2008, 07:27 AM   #10
spooky
spooky
spooky's Avatar
Drives: camaro
i sit? whew that's good. i really don't see it very appealing to have tire trouble and have no spare. seems like so much hassle.
spooky is offline   Reply With Quote
Old 11-28-2008, 08:11 AM   #11
Rallyman6
Member
Rallyman6's Avatar
call AAA
Old 11-28-2008, 08:20 AM   #12
ihc95
ihc95's Avatar
Drives: BMW 335i E92
ihc95 is offline   Reply With Quote
Old 11-28-2008, 11:57 AM   #13
Arioch
Drives: 2010 Camaro Victory Red 2SSRS
Here's a question, even if you get the spare tire (lets say on the non-SS, but even think about this in terms of an SS) would the trunk allow you to put the flat tire into it? The width on the trunk opening looks narrow. If you had a large rim would it even fit into the trunk? Meaning is a spare tire going to do you any good if you have to abandon the rim or put the rim in the back seat?
I could be wrong its just something I was wondering about. Maybe a 21" rim will fit in the trunk after you strip the tire off of it, but if thats the case hopefully you'll have the tools to do that when you get the flat.
Arioch is offline   Reply With Quote
Old 11-28-2008, 12:37 PM   #14
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
are there any 20" all-weather tires out there? card21doc Wheels and Tires Talk Sponsored by The Tire Rack 11 01-15-2010 09:11 PM
Minimum size wheel on SS Brembo Brake JEFF2010SSMANUAL Wheels and Tires Talk Sponsored by The Tire Rack 57 10-21-2009 02:04 PM
We want all season tires for the SS Rogue Leader Wheels and Tires Talk Sponsored by The Tire Rack 72 01-07-2009 08:02 PM
