BORLA
Old 08-12-2010, 09:55 PM   #1
Diesel Don
Drives: 2010 VR 2SS M6
Exclamation JBA Hi-Flow Cats / Midpipes CEL
Strangely enough I just got a CEL on my otherwise stock SS---~500 or so miles after installing the JBA midpipes.
P0430 - Catalyst efficiency below threshold (bank 2)
- Looks like it threw the same code twice at the same time (if possible?)
Now I don't know what to do.
1. Go through the hassle of putting the stockers back on; and lose all of the sound (which kicks ass), and the performance (which was a BIG gain).
2. Get a tune. Which means I lose my warranty which I really need because I want them to fix my piss-poor clutch and horrible rear diff noise (low speed turns).
3. Ignore the light / reset it every Xxxmiles. (Warranty questionable)
Input? No one else having this problem yet? I bought these cats thinking that several members had more miles than this with no CEL.
Thanks
Diesel Don is offline   Reply With Quote
Old 08-12-2010, 10:38 PM   #2
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
had mine on for over 1,200 with plenty of hard accelerations. Also had borla s type and c.a.I. No tune, no CEL yet. Sounds meaner than ever, ordering jba shortys in a week. I'll report to the forums how that goes.
ducq is offline   Reply With Quote
Old 08-12-2010, 11:28 PM   #3
Diesel Don
See that's what is driving me crazy. I can't find ANYONE with this problem so far. What the heck?
1. Is it possible that I installed them improperly?
2. Could it be a defective set?
3. Are California-purchased Camaros different in any way regarding emissions, ECM programming, etc.? I hate CA btw...
4. My car was purchased at the end of August 2009, so i guess it is fairly early number car. Are there any ECM updates that a dealer could do? (semi-unrelated question) My dealership really sucks and no one there knows anything about anything. Like really worthless.
A couple of other unrelated notes:
a. buyjba.com is great. I ordered from them on a Friday late at night thinking they would take a week to get to me. I get a call on Sunday from them saying that they are local and would drop them off I'd like. Great service, awesome price.
b. I am going to try to contact JBA tommorow. I think they are somewhere here in California. I will also say I was somewhat concerned when I saw that the box said made in mexico, because I was under the impression that they were manufactured here in California. My midpipes had pretty bad burrs in the I.D. of the flanges, and the back o2 sensor bung locations puts the o2 sensors VERY close to the transmission. So I'm not sure I'm really thrilled with the fit and finish-related quality of the product.
Seriously any input would be great.
Old 08-12-2010, 11:44 PM   #4
LosXC451
LosXC451's Avatar
Drives: 2010 SS SIM w/ RS
Most likely number 1, try maybe taking a look under the car to see that everything on right
LosXC451 is offline   Reply With Quote
Old 08-12-2010, 11:55 PM   #5
Diesel Don
I'm going to take a look this weekend. It was pretty straightforward however. The only think I was worried about AT ALL was that the exhaust manifold-to-midpipe connection could possibly leak due to: a) somewhat questionable fit and b) their crap nut-and-bolt design on the flanges. Man was that a pain in the ASS! Why couldn't they just put a stud on there? I know this has been observed by others on here....
So then do you think that if lets say that connection has a little leak (which I have no evidence at this time that it does) that could cause the code I have? i.e. cat efficiency below threshold?
edit: I put a small amount of nickel anti-seize in all the bosses for the o2's. I suppose there is the possibility of a minuscule amount of that stuff getting on to the actual sniffer part of the sensor, although I consciously and actively tried to avoid that from happening.
Old 08-13-2010, 07:35 AM   #6
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
I've had my JBA midpipes on probably the longest of anyone on this site. I have never popped any CEL codes. I agree that the fitment is not that great with these pipes. I too noticed that they were made in Mexico. I also worried that the driver's side midpipe would not seal at the coupler clamp because it was shorter than the stock pipe (I just split the difference with the clamp).
In addition, one thing I never mentioned in my original thread is that I had huge hanging chads inside the O2 sensor bung-holes (sorry I'm laughing as I write that ) when I first got the pipes. These chads were due to the drilling of the pipe to put the bung in. I managed to wiggle them back and forth in the bung-hole with my pinky until they broke off.
Anyway...I ditched the grade 5 crap hardware that came with the midpipes and went out and bought some grade 8 flange head bolts, nuts and washers at the hardware store. I've never had a leak.
I'm thinking you may have a leak somewhere causing the code. As long as you put the nickel anti-seize on the threads of the bung-hole or sensor and not on the O2 sensor itself, you should be fine. I used nickel anti-seize too.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 08-13-2010, 08:23 AM   #7
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
My JBA threw a code with in 50 miles...i emailed JBA and they DO have great service...ended up having to take them off and sell them on here...I had a different code though...my electric cut outs are right near the rear O2 sensor...the extra flow from the JBAs and the extra O2 it was reading from the cut outs were causing it to throw the lean code. But JBA got back to me through E Mail on a Saturday within an hour giving me ideas of what it could be and even looking up a certified or known JBA installer in the NJ area, so A+ for them on their half!!
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 08-13-2010, 09:37 AM   #8
2010 4 DW
Drives: White 2010 RS/SS
I would clear the code and see if it comes back. I had a CEL when I first put them on as I did not disconnect the battery when I installed. Never had a cell after that for 2500 miles.
DW
2010 4 DW is offline   Reply With Quote
Old 08-13-2010, 10:27 AM   #9
Inferno2SS
Inferno2SS's Avatar
Drives: 2010 IOM 2SS/RS
I have around 600 miles on my JBA and no issue with a CEL coming up.
Inferno2SS is offline   Reply With Quote
Old 08-13-2010, 10:39 AM   #10
Rick2010
Chevrolet's & NY Yankees!
Rick2010's Avatar
Drives: ALL CHEVROLET'S
First.....
I love JBA!!! The shortys and the 3" cat back are unbelieveable.....but...
I think the Solo Cats are built better...02 placement is like stock....
and made in Buffalo NY....only reason I did not do JBA Cats...
Rick2010 is offline   Reply With Quote
Old 08-13-2010, 10:41 AM   #11
Hicompression
Rumbly Bumble Bee
Originally Posted by IndeedSS View Post
If you don't find any issue with the installation, you could just buy the O2 extensions from SOLO.
Or...save even more money and go down to Autozone and buy a spark plug anti-fouler and use it instead.
-OBX Longtubes FTW!
Old 08-13-2010, 11:56 AM   #12
MaroSS
ZL1
MaroSS's Avatar
Drives: 10' SS/RS - Sold; 15' White ZL1
Same here no codes with my High Flow Cats and I also have Noweeds Diverters and no Tune. The fitment is horrible tho but in your case i think you should put back on the stock cats and see what happens.
MaroSS is offline   Reply With Quote
Old 08-13-2010, 02:01 PM   #13
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Take them off and send them to me....
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 08-13-2010, 03:57 PM   #14
oachalon
Originally Posted by Rick2010 View Post
First.....
+1. Im not from New York but it is worth the extra money to support a company that makes their products in the USA.
oachalon is offline   Reply With Quote
cel, jba, midpipes, p0430
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 08:43 PM
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 03:51 PM
JBA High Flow Cats ZuluKilla8 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 9 08-04-2010 06:04 AM
New JBA 1 7/8 LT Headers w/hi flow cats - $1100 obo SS 376 Local Marketplace 0 06-27-2010 12:30 PM
jba long tube headers and full flow cats desiel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 06-10-2010 11:18 PM
