JUICEDMOTORSPORTS
Old 08-13-2010, 10:32 PM   #1
sewwhut
sewwhut's Avatar
Drives: 09busa,67sub,96tahoe,baja5t
Adjusting clutch engadgement
is it possible to adjust the clutch pedal so that it engages closer to the floor?
sewwhut is offline   Reply With Quote
Old 08-14-2010, 09:17 AM   #2
sewwhut
sewwhut's Avatar
Old 08-14-2010, 12:30 PM   #3
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
Good question(watching)
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 08-15-2010, 07:02 PM   #4
Russell James
Russell James's Avatar
Drives: '69 Drag, #37 TA Stock Car, '15 ILE
not adjustable. If the engagement point is off, you have to fix what's wrong. Such has bleeding or changing the slave. If the clutch ever overheated, the fluid and slave could be messed up.
Old 08-16-2010, 09:46 AM   #5
Fast vette
Fast vette's Avatar
Drives: 2SS IOM M6, 71 ElCamino, 00 Sierra
Yep, bleeding should do the trick.
When you press on the pedal you must sense a little resistance after an inch of travel at the most like the pedal is doing something, if you push it almost halfway and you don't feel like it's doing anything you have to bleed it.
There are only two auto manufacturers; GM and everybody else...
Fast vette is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 11:51 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
