Rick@Livernois
Old 08-14-2010, 07:54 PM   #1
plastrd
Indecisive
Drives: 2010 Camaro SS/RS
Clutch stuck for first time
I revved her up to around 3500rpm and popped the clutch to do a burner the other night. Unfortunately the clutch stuck about halfway up and although I realized the tires weren't spinning and let up quickly, I still smoked the clutch a bit (that great smell filled the cabin).
I drove normally the rest of the way home and it seemed fine, I've been driving like I usually do (aggressive, but not jerkwad) and that all seemed fine too. This is the first time this has happened, it didn't happen a few months back when I took it to the strip and did 12 runs in relatively quick succession. I popped the hood and checked the brake/clutch reservoir and found this:
So obviously I boiled the fluid and it relieved itself out the cap. The level still seems fine now so I'm just thinking of ways to prevent this from happening again. I have a couple driving technique questions for you guys:
When I begin slowing down for a stop or a corner, I usually downshift and smoothly engage the clutch to engine brake. Is this adding significant heat to the system that might cause a boil situation like this next time I launch hard? Do you typically try to rev-match when downshifting?
Some of the other threads suggested a separate reservoir for the clutch fluid. It seems like this is a cheap and easy mod so I figured I might as well. I'm not too keen about hunting through a junk yard, is there a new reservoir I can buy online inexpensively that will be a good fit for the car?
Any other tips to be nice to the clutch without driving like a granny?
plastrd is offline   Reply With Quote
Old 08-14-2010, 07:58 PM   #2
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
Go to your chevy dealer and get a GTO res. and install it sep from the brake with better Fluid...
Capthowdy is offline   Reply With Quote
Old 08-14-2010, 09:49 PM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Old 08-14-2010, 10:10 PM   #4
plastrd
Indecisive
Do you happen to have a part number for it? I found some kits online for over $200. I was under the impression from other threads that this was a $20 part.
Old 08-14-2010, 10:38 PM   #5
2SSRS@Gen5diy
In this thread in post 13 and you need to replace the fluid before and after you go to the track.
http://www.camaro5.com/forums/showthread.php?t=34085
Old 08-14-2010, 11:16 PM   #6
plastrd
Indecisive
Aha! That's exactly the info I was looking for, thanks.
Old 08-16-2010, 08:40 AM   #7
Fast vette
Fast vette's Avatar
Drives: 2SS IOM M6, 71 ElCamino, 00 Sierra
Definately a good idea to go to the seperate reservoir and fill it with something like Wilwood racing brake fluid. I got tired of searching for a new reservoir that I liked ( GTO or aftermarket ) so went to the boneyard and got one off of a Cobalt I think it was.
Better to rev-match when downshifting, a little less fun but why downshift all the time? Better to wear down the brakes than the clutch and the engine.
There are only two auto manufacturers; GM and everybody else...
Fast vette is offline   Reply With Quote
Old 08-16-2010, 11:04 AM   #8
flyby
Drives: 2010 Silver SS
I've had my clutch stick several times, never had anything happen to reservoir. However, I did burn up the clutch.
flyby is offline   Reply With Quote
One year ago today....(long read) dtm4192 5th Gen Camaro SS LS LT General Discussions 23 07-18-2010 09:34 AM
Clutch issues. Anybody else seen this before? H & E Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 47 05-21-2010 02:38 PM
Odd clutch and shifting issue for me. armysig Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 02-22-2010 11:36 AM
Coming Soon! RAM Twin Disc Clutch and Flywheel! Taking Pre-Order List @BMC Peformance Kris@BMCPerformance V8 Bolt-Ons & Tunes 7 02-18-2010 07:00 PM
Clutch sticking again KATHY63 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 09-21-2009 07:50 PM
