BORLA
Old 08-14-2010, 09:36 PM   #1
Rob
Drives: Red Jewel Tint
Skip shift eliminator problem
I installed an SLP skip shift eliminator today. I believe the eliminator works well. However I now have difficulty getting in reverse. Does the eliminator affect the reverse lock out? Anyone else have this happen?
Rob is offline   Reply With Quote
Old 08-14-2010, 09:38 PM   #2
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
It's on backward, flip it around and you'll be good..
CaniacFan is offline   Reply With Quote
Old 08-14-2010, 09:43 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
There are two plugs on the transmission that the skip shift eliminator will fit, the CAGS solenoid and the reverse lock out. Plugging it into the wrong one is a common mistake. The skip shift solenoid is located half way up the transmission case, towards the top, on the drivers side.
Old 08-14-2010, 10:04 PM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Did you ever see so many wires coming out of a manual transmission? Holy cow! Mine works perfect, but it does not eliminate the display showing you should shift from first to fourth.
Old 08-14-2010, 10:12 PM   #5
Apex Motorsports
The only way to get rid of the display is a tune, the skip shift eliminators kill the lock out but not the display on the dash.
Old 08-14-2010, 10:26 PM   #6
PAUL SS
PAUL SS's Avatar
I can live with the display.
Old 02-23-2011, 02:29 PM   #7
mospeed
Drives: 2011 Chevy Camaro 2SS RS
Send a message via Skype™ to mospeed
I just installed this yesterday. Reverse is now difficult to get into. Nothing is showing up on the display now and have not had to sift into 4th. So it seems to work except the reverse difficulty.
mospeed is offline   Reply With Quote
Old 02-23-2011, 04:14 PM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
See Post #3 Above. You have it plugged into the wrong place.
The 1-4 graphic will still come up in the Driver Information Center on the dash but the lockout will not happen when the unit is plugged in right. Try installing again using the right sensor. You need to look higher up on the tranny.
-Mark.
Old 02-24-2011, 06:26 PM   #9
mospeed
Yup, it was in the wrong place. Working great now thanks to this thread!
-Mark
Old 02-24-2011, 06:56 PM   #10
JoesSS
JoesSS's Avatar
Drives: 2010 1SS/LS3 Summit White Camaro
-Mark
How were you able to get it plugged in on top of the tranny? I can't get my damn hand up there!
JoesSS is offline   Reply With Quote
Old 02-24-2011, 07:39 PM   #11
LadyT_SS
Christina
Drives: Red Jewel Tint 1SS
picture pls!
LadyT_SS is offline   Reply With Quote
Camaro Skip Shift Eliminator.... southerncarparts V8 Bolt-Ons & Tunes 12 01-14-2018 09:46 AM
CAGS (aka: Skip Shift) Apex Motorsports 5th Gen Camaro SS LS LT General Discussions 108 06-25-2010 09:26 PM
Hurst Billet/Plus 2 Shifter $319.95, get Skip Shift Eliminator FREE! Apex Motorsports Transmission / Driveline 22 06-15-2010 10:55 AM
M6 Owners and Skip Shift Beware! DkknightX 5th Gen Camaro SS LS LT General Discussions 173 01-26-2010 05:14 PM
