BeckyD @ James Martin Chevy
Old 08-15-2010, 08:56 PM   #1
mbspeed
mbspeed's Avatar
Drives: 2015 CAMARO SS LS3
problems with borla axle back exhaust
please help i have ss/rs ls3 and i got a borla s type axle back exhaust installed ..the sound was not the nice borla sound i been a custom to in the past it has a bad drone sound when cruzin on freeway i returned it and got a borla touring axle back its better but still not what i think a 400 + hp camaro should sound like its very quit when your on the gas but at cruzin speed it sounds like 4 a cylinder honda what am i missing this is driving me crazy would a x pipe correct this i feel like i recked the car cuz the stock system sounds better just looking for a deep sound have any you guys had problems like this i have put over 10 aftermarket exhausts on cars and trucks and never had this kind of problem last i was thinking about trying the new dyno max system ...please help me make the car sound like it should dont know what to do and i have listen to all exhaust clips
mbspeed is offline   Reply With Quote
Old 08-15-2010, 09:05 PM   #2
Steve
Ancalagon The Black
Steve's Avatar
Drives: 2004 Silverado 4X4, 2010 RJT 1SS
I was at a car cruze night last weekend and sitting next to an 07 Carol Shelby Mustang. I was a beautiful looking machine. In any case, he had installed a Borla cat back system and mentioned that it needed to be "burned in", meaning that the sound changed with time. Maybe that will happen with you?
Steve is offline   Reply With Quote
Old 08-15-2010, 09:14 PM   #3
Express96
Express96's Avatar
Drives: 2010 Camaro 2SS/RS
Its not the exhaust...it's when the car goes from 8 to 4 celynders. I just had a magnaflow catback exhaust installed and mine does the same thing, it did it before with the stock...just not as noticeable.
Express96 is offline   Reply With Quote
Old 08-15-2010, 10:20 PM   #4
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
he has an ls3 so theres no AFM...
are you looking for a deeper/more pronounced tone, or for less drone?
MileMAN402 is offline   Reply With Quote
Old 08-15-2010, 10:39 PM   #5
jpizzle007
jpizzle007's Avatar
Drives: '10 LS3, '11 328i, '78 El Camino
that is the longest run on sentence ever.
jpizzle007 is offline   Reply With Quote
Old 08-15-2010, 10:41 PM   #6
mbspeed
mbspeed's Avatar
yes ss 6m i think on a auto it may be fine but if i am not in a low gear sounds like hell and it may get worst after packing burns out i dont know if getting a full cat back will help.. do any guys run the dynomax axle back
Old 08-15-2010, 10:51 PM   #7
SSLarry
Drives: 2SS LS3
I ordered the Borla Touring axle back as soon as I got my car. I knew it was the sound I wanted. Quiet when I need it to be, but deep sounding when I get on it (4500-6000 rpm).
Edit:
Come to think of it... I do get a drone in top gear, sub 1800 rpm. It's not terrible, but is such a low frequency that its noticeable. Nothing the Boston Acoustics can't handle.
SSLarry is offline   Reply With Quote
Old 08-15-2010, 10:58 PM   #8
bkscott
bkscott's Avatar
I have the same setup. Give it some time. It will change and you will get used to the drone or it may lessen some overtime. At 1st I thought I made a mistake too. Had the car on the highway, and it was awful.
Now no problem.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 08-16-2010, 03:09 PM   #9
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
Me too. Thought I had made a big mistake. I then added the Borla cat back with x pipe, and although it still drones, the tone is deeper. Once you get to 2200 rpm the drone goes away but by then you are doing 90! Need to add 4:10 gears.
mrvenicess is offline   Reply With Quote
Old 08-16-2010, 08:25 PM   #10
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 99 Silverado
Give it some time. If you don't like it or it doesn't change after a 1000 miles someone here will take it off your hands and you can try something else. Save the $ for now or you'll go nuts trying this and that.
molsonbrador is offline   Reply With Quote
Old 08-22-2010, 09:52 PM   #11
SS4PK
SS4PK's Avatar
Drives: 2010SS
I have the S-type axel abck and like it a lot.
Her Hot Rod.
SS4PK is offline   Reply With Quote
Old 08-22-2010, 10:02 PM   #12
ProudLS
ProudLS's Avatar
Drives: Camaro SS
I had the same problem when I was running without Cats, then I installed hi flow cats from ARH and the noisy sound at 2500 is gone
2010 Black/Black SS RS M6, ARH headers, Hi-flow cats w/x-pipe, Fastlane CAI, Livernois Camshaft 2C, SLP 160 Stat, SLP underdrive pulley, Hurst, Eibach lower spring, BMR lower control arms, BMR toe rods, Razzi body kit and Borla axle back. Tuned by me HPT.
ProudLS is offline   Reply With Quote
Old 08-23-2010, 10:31 AM   #13
mrvenicess
mrvenicess's Avatar
I just installed Fat Mat insulation in the trunk and it toned down the drone at 80 from my Borla S type cat back.
Old 08-23-2010, 10:34 AM   #14
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
I have MRT and it has the 2k drone also. (rpm 2,000)
skar is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
My New Magnaflow Comp Series Axle Back Exhaust Buffnshine USA - California 17 05-08-2010 08:07 AM
5 Borla Axle Back Exhausts left instock until Back Order! #11775! FREE SHIPPING IPS Brandon V8 Bolt-Ons & Tunes 1 09-30-2009 05:00 PM
Finally got my Borla axle back installed! Rob53 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 08-24-2009 04:06 PM
