BeckyD@RodgersChevrolet
Old 08-15-2010, 08:08 PM   #1
ablackburn99
ablackburn99's Avatar
Drives: 2010 CAMARO 2SS/RS LS3 VR
GEAR RATIO VS. SMALLER TIRE DIAMETER
I was looking for some new light wieght wheels and tires. TSW Nurburgring w/ Hankook Ventus V12 Evo K110
2010 Camaro 2SS LS3
Factory
(2) Front 20 x 8 + 35mm P245/45R20 = 28.7" tall.......(1)W-30.3 lbs (1)T-32 lbs = 62.3 lbs
(2) Rear 20 x 9 + 45mm P275/40R20 = 28.7" tal.............(1)W- 32 lbs (1)T-36 lbs = 68 lbs
.................................................. ...........................................All 4 sets = 260.6 lbs Total
New
(4) All 19 x 9 + 20mm P275/40R19 = 27.7" tall..........(1)W- 29 lbs (1)T-19.5 lbs = 48.5 lbs
.................................................. .............................................All 4 sets = 194 lbs Total
.................................................. ....................................Wieght savings = 66.6 lbs Total
new wheels and tires move wheels 28mm closer to fender in front
new wheels and tires move wheels 25mm closer to fender in rear
new wheels and tires are 1" smaler diameter
Anyone know if these will work, have a similar set up, or know the pros and cons. Especially with the new tires being 1" shorter. I thought this might help save wieght and help with gearing ( vs 3.73 or 4.10 ).
Also looking for a pirce if any venders sell these.
Good link for size and offset
http://www.e90post.com/forums/showthread.php?t=255743
ablackburn99 is offline   Reply With Quote
Old 08-16-2010, 01:44 AM   #2
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
This will change your gear ratio and speedo but im not sure how much. This will also create MORE fender gap so it will look worse IMO. It will also give you less ground clearance which might be an issue for you too. There are alot of light weight wheel options in 20" you might look into. If there was such a size of 295/40ZR19 or 275/45ZR19 it would be around the same diameter as stock. Good luck
Old 08-16-2010, 04:51 AM   #3
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
A 1 inch reduction in tire diameter will change the overall gear ratio by 3.4% - not much.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 08-16-2010, 06:10 AM   #4
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
A smaller wheel/tire diameter will lower the height of the car by half of whatever the change in tire diameter is. If you go too far, you may bottom out/scrape driveway entrances, etc. You also want to be careful not to go so small that the wheels don't fit around the brakes. You'll probably have to get the speedo re-calibrated too.
I guess the pros would be lower unsprung weight, lower rotational inertia. However, you can accomplish this with aftermarket 20" wheels.
If you are looking for better gearing, I'd just put in different gears. Probably less that can go wrong, since the ride height, handling, steering, alignment, and other characteristics of the car would be optimized by GM's engineers for the wheel/tire size that come on the car. Besides, gears would have more of an effect (going to 19s would only be the equivalent of going to a 3.63 gear).
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 08-16-2010, 02:28 PM   #5
ablackburn99
Added some wieght figures to original post.
Total wheel and tire Wieght savings = 66.6 lbs not to bad!!!
Old 10-11-2013, 10:18 AM   #6
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
It's OK, but it's sprung weight savings. Unsprung weight savings is where things get FUN!
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 10-11-2013, 01:50 PM   #7
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Rotational mass reduction has its own advantages. That kind of savings will be felt for sure.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 10-12-2013, 01:46 AM   #8
toNspahreP
Drives: SS
Your weight for the 19" tire is wrong, unless you magically think there is only 1/2 to 2/3 the rubber of the 20" tire present. They weigh 31.03 pounds a piece
toNspahreP is offline   Reply With Quote
Old 10-12-2013, 06:19 AM   #9
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Wheels and tires are unsparing weight.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 10-12-2013, 12:54 PM   #10
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Rhino is correct. Unsprung weight means weight that is not supported by the springs, such as wheels, tires, brakes, hubs, lower control arms, etc.
Rotational mass refers to items that get, uh, rotated, when the car is in motion.
Reducing both pays substantial dividends.
If you want "fun with numbers," just take the new overall diameter and divide it by the old diameter. That number tells you the percentage of the original diameter, and in this case, it will naturally be a smaller number than 1.0. It's also a useful number to compare speedometer readings, as you can multiply that result against your speedo reading to get a true readout at any speed (provided the speedo was correct in the first place).
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-12-2013, 01:57 PM   #11
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Is a helmet delete considered rotational mass?? Bc I'm usually rotating around to look to see how far I'm in front on a Mustang while I'm going down the
track?
Camarojt is offline   Reply With Quote
2010 Blue SS for $32990 and we pay for your plane ticket! Mitsubishi in Syracuse Dealer Camaros for Sale 0 12-21-2009 12:42 PM
2010 Camaro SS for sale in Syracuse NY Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 4 12-10-2009 10:15 PM
2010 Camaro SS V8 in Syracuse NY-FREE TRAVEL TO PICKUP Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-10-2009 04:23 PM
Slightly smaller diameter tires a problem? Stevo Wheels and Tires Talk Sponsored by The Tire Rack 5 12-10-2009 08:25 AM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 05:11 AM
