SDTW Custom Wheels & Tires
Old 08-16-2010, 12:58 PM   #1
Rob191288
Rob191288's Avatar
Drives: 2010 Camaro LS
Thumbs up DIY Transmission Fluid change V6
Ok so I changed out my trans fluid today in my LS with a M6 and I must say its pretty easy, first I went to the dealer and they looked at me crazy because I was wanting my fluids changed and there is only 1500 miles on the car, then he was like alright we can do it but its going to be $140, I kindly told them to screw themselves, so I took it to my buddy who owns a garage and we did it. Now since I have done it I find that its easier to shift through the gates and its a smoother transfer between gears, plus im glad I kinda did it because the V6 requires 1.9 qts and I'm pretty sure I barely got a 1 QT out of it (someone at GM messed up). So if your having problem with stiff shifting try changing out your oil and see if its any better.
Now as far as fluid the V6 uses: 75W-90 Gear oil and it holds 1.9 QTS.
V8 uses: transmisson fluid and it holds 3.65 QTS
The first pic shows the drain plug. Its directly under the transmisson and mine was marked with a green mark on it.
The second pic is the fill plug. Its about half way up and a little behind the drain plug on the drivers side of the tranny.
Hope this helps out my fellow C5 members with the V6
Rob191288 is offline   Reply With Quote
Old 08-17-2010, 08:00 AM   #2
Silver1lt
Chevy Tech
Silver1lt's Avatar
Drives: 2012 Equinox 2LT
Send a message via AIM to Silver1lt
spill and fill usually runs around $75-$90 around here....
Rich Doherty Malden Ma
2010 Silver Camaro 1LT Black Stripes V6 6Speed K&N Intake Traded for a 2012 Equinox :( Family's growing
Silver1lt is offline   Reply With Quote
Old 08-17-2010, 08:33 AM   #3
mdinferno
mdinferno's Avatar
Drives: 2010 IBM 2LT/RS
This is excellent.... I did mine about 2 months ago.. when i did a search it was only info and pic for a V8...
mdinferno is offline   Reply With Quote
Old 08-18-2010, 10:11 PM   #4
Rob191288
Rob191288's Avatar
haha must be nice, yea my dealer told me that they charge $140 to mess with the tranny.
Old 08-25-2010, 06:15 PM   #5
larryt1026
larryt1026's Avatar
Drives: 2011 Camaro LT
This is exactly what I was looking for! Thanks! Now after you locate those two things, what do you do from there? Can you please provide some instructions from start to finish? I'm new to this lol..
larryt1026 is offline   Reply With Quote
Old 08-28-2010, 11:39 AM   #6
Rob191288
Rob191288's Avatar
Take out the fill plug and then take out the drain plug that way the air can flow through it and get the fluid out. After its completely drained put the drain plug back in place then take the fluid along with either a pump or a about a 4 foot tubing that you can run down through the engine compartment and being filling, once its full you with know because the fill plug will begin overflowing. It should take aprox. 1.9 QTS
Old 09-23-2010, 08:22 AM   #7
khabboub
Tampa Gulf Coast Family
khabboub's Avatar
Drives: 2010 Black Camaro 2LT M6
This is going to help out.
khabboub is offline   Reply With Quote
Old 09-23-2010, 01:57 PM   #8
merritr
GM Enginerd
Drives: Cyber Grey 2LT RS
The Aisin AY6 transmission (V6 manual) fluid capacity is 1.8 liters/1.9 quarts but the Tremec 6L80 transmission (V8 manual) is 3.9 liters/4.2 quarts. The quarts measurements are rounded values when converting from liters.
merritr is offline   Reply With Quote
Old 01-25-2011, 09:27 AM   #9
PB3
PB3's Avatar
Drives: 2010 CGM 2LT/RS/GFX/M6
Does the car have to be on during fill up?
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
PB3 is offline   Reply With Quote
Old 02-03-2011, 12:16 PM   #10
eckerj
Drives: 2010 Camaro 2LT
Two questions:
1) Is it a good idea to warm up the engine/transmission before changing it?
2) How would ramps affect draining or filling? Would ramps help it drain easier, but then off ramps for filling?
Thanks much
eckerj is offline   Reply With Quote
Old 02-03-2011, 04:21 PM   #11
xtreme industries
Drives: 2010 Camaro 2lt RS
car must remain horizontal for the tranny to be filled correctly.
warm fluid does flow better but it may be too hot to handle. best to do it cool and just give it time to drain.
xtreme industries is offline   Reply With Quote
Old 02-06-2011, 07:50 AM   #12
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
No, only automatic transmissions need the engine running during fill.
IamJacksCamaro is offline   Reply With Quote
Old 02-07-2011, 11:41 AM   #13
PB3
PB3's Avatar
Nice! Thanks!
So if the car has to be completely horizontal the only way to change it would be if the car was on a lift? Bummer.
Old 02-08-2011, 06:20 PM   #14
xtreme industries
Nice! Thanks!
you can set the front on ramps or jack stands, then lift the back and place the jack stands under it. just mak sure it is level, then get under it and change the fluid.
Sealed Transmission?? Transmission fluid doesn't need change until 150k miles? DevilKnightFalcon Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 12-07-2009 06:32 PM
