HeadlightArmor
Old 02-08-2011, 07:25 PM   #15
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
You can also jack it up, take out the plugs (with a drain pan in place) and lower the car until drain is complete. Jack back up, replace drain plug, lower and and begin filling. No lift or stands required.
Old 02-17-2012, 12:43 PM   #16
DON_RAFA
NY5THGEN
DON_RAFA's Avatar
Drives: 2010 Camaro 2LT/RS/A6/SIM/IO
Originally Posted by IamJacksCamaro View Post
No, only automatic transmissions need the engine running during fill.
Just curious but why does the auto have to be on during drain/fill? (I have an auto)
DON_RAFA is offline   Reply With Quote
Old 02-17-2012, 01:00 PM   #17
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Because unless the trans fulid is at operating temperature it will give you an inaccurate reading. The trans should read full when hot not cold. otherwise you will overfill it.
When changing an auto transmissions fluid, fill it up after you drain it. Then start the car and let it warm up. Once its warm top it off then run the trans though each of the gears a few times. Check it again and top if off. Then take it for a drive, checking and topping off after.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 02-17-2012, 01:24 PM   #18
DON_RAFA
NY5THGEN
DON_RAFA's Avatar
Thanks a lot now I know
Old 08-29-2012, 03:25 PM   #19
Rocks RS
Rocks RS's Avatar
What size sockets are needed for this job? I have heard 15/16.
2010 Camaro 2LT / RS - Black w/IO interior & M6
Sporting MRT V1, Hurst short throw, and Injen long tube and loving it!!!
Also, over 125,000 miles and going.
Rocks RS is offline   Reply With Quote
Old 05-19-2013, 03:48 PM   #20
elpatofeo
LawBraker
elpatofeo's Avatar
Drives: 10 SIM 2LT/RS & 2016 1SS Hyper Blue
so my V6 manual transmission uses 75W90 engine oil and not transmission fluid? I just want to be 100% sure because I was abou to put transmission fluid it in. Please confirm before I do anything else. Thanks for your help!
elpatofeo is offline   Reply With Quote
Old 05-19-2013, 04:01 PM   #21
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
Originally Posted by elpatofeo View Post
so my V6 manual transmission uses 75W90 engine oild and not transmission fluid? I just want to be 100% sure because I was abou to put transmission fluid it in. Please confirm before I do anything else. Thanks for your help!
Yeah, don't put automatic transmission fluid in a manual...
Toasty is offline   Reply With Quote
Old 05-19-2013, 04:12 PM   #22
elpatofeo
LawBraker
elpatofeo's Avatar
thanks for your help guys...almost made a big mistake.
Old 06-30-2013, 01:26 AM   #23
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
And so the automatic uses standard transmission fluid?
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 06-30-2013, 07:53 AM   #24
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
The automatic uses DEXRON VI transmission fluid.
etmx183 is offline   Reply With Quote
Old 06-30-2013, 09:35 AM   #25
efpardo
Deep6
efpardo's Avatar
looks pretty easy to do by yourself. I was quoted $200.they also didn't know but they thought this vehicle might take 16 quarts.
My Journals:
Old 07-15-2013, 06:38 PM   #26
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: 2011 2SS L99 SGM 2013 2SSRS LS3 BRM
I did this yesterday, the site was down but I was still able to find your pic's of the drain and fill plugs on google images!! Thanks for posting this.
cadyshac is offline   Reply With Quote
Old 08-16-2013, 10:11 PM   #27
suzbndt
suzbndt's Avatar
Drives: 2010 Camaro SS 2011 Mustang GT
tr6060 uses atf
suzbndt is offline   Reply With Quote
Old 08-21-2013, 01:18 AM   #28
jmss
Drives: 2010 camaro ss
The A6 holds 4.2 quarts?
jmss is offline   Reply With Quote
Sealed Transmission?? Transmission fluid doesn't need change until 150k miles? DevilKnightFalcon Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 12-07-2009 07:32 PM
