Emblempros
Old 08-16-2010, 03:27 PM   #1
ericedelman
ericedelman's Avatar
Drives: 2017 ZL1 (on order)
Have you done a brake upgrade for road course use?
I use my car on road courses - Pocono, NJ Motorsports Park, Summit Point, Watkins Glenn, etc.... I'm also planning to take the car to run One Lap of America next spring.
I'm using OEM take-off rotors, Hawk HP+ pads, Goodridge lines, Superblue fluid.
The rotors and front pads made it through 4 track days. The rears could probably make it though 6 or 8 track days. I don't care about the noise and dust from the pads, and frankly, these take-off rotors are $60 delivered, so I'm not in a big hurry to buy $500 racing rotors.
What I am concerned with is the calipers. Knocking those slider pins out and then hammering them back in makes me nervous. How many times can I really do that before I damage the caliper or pin, and I'm concerned it's not going to be obvious and will fail at a bad time.
So, if you upgraded calipers, let me know what you did and how it's working out. I am satisfied with the cars ability to stop right now. The issues are rotors warping and the slider pins in the calipers. Or if you just want to talk about brakes, that'd be fine too.
2017 ZL1 (on order)
ericedelman is offline   Reply With Quote
Old 08-16-2010, 03:59 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Search for what Pedders did with CTS-V calipers/rotors. There's a new thread with some comments on pads and what-not, too. This is a direction I'd seriously consider because I'm all about making sure I have access to replacement parts when I need to.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-16-2010, 04:08 PM   #3
600hp-lpe
Drives: 2010
it's a thread in this section labeled "Z28 brakes if I ran GM". Good info on brakes in there...
600hp-lpe is offline   Reply With Quote
Old 08-16-2010, 05:16 PM   #4
Mr Twisty
Mr Twisty's Avatar
Most excellent thread, yup!
http://www.camaro5.com/forums/showthread.php?t=71401
It looks like the CTS-V set uses a larger diameter pin. Maybe Pete will chime in on the durability of the pins.
-- Benjamin Franklin
Old 08-16-2010, 05:31 PM   #5
thekid96
Drives: Z06, 69 Camaro
I upgraded to a Stop Tech BBK several months ago, the differences are astounding. There is no comparison in brake feel, modulation, lack of fade and overall stopping power. Sure they are pricey but you definitely won't want to drive on stock brakes after you experience the Stop Techs.
thekid96 is offline   Reply With Quote
Old 08-16-2010, 08:34 PM   #6
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
+1 on the Stop Techs. They are great and they look great as well. The CTS solution was a good cheaper solution for those not wanting to upgrade with a full big brake kit. But, the amount that your using/going through pads/rotors, you may as well just upgrade the entire system. Good luck!
Z Madness is offline   Reply With Quote
Old 08-16-2010, 08:59 PM   #7
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
There is no question you can spend a lot of money on high quality brake upgrades. Before you do, let me ask a question or two. You don't seem to feel you r current brakes are not up to the task. You seem to be getting decent life out of them. Aside from the pins is there anything else that you are not satisfied with your on track brake performance?
Old 08-16-2010, 09:54 PM   #8
ericedelman
The brakes are fine for most of the track use I do. I had problems during a day on the long course at Pocono, where I was slowing the car down from 140+ to probably 40 or so to get back into the infield on the course. The course runs counterclockwise, it's going into the turn at the top.
I'd guess this is how the last set of rotors warped. And towards the end of each session, the brakes faded off some. Not to the point of no pedal, but they were hot and working less efficiently.
But my big concern is those slider pins. They just don't seem secure, and I don't like knocking them in with a hammer and smacking the caliper. I'd be much happier with a bolt. I'm sure Brembo knows what they're doing, but it would make me more comfortable in the car.
That's a good question you brought up though. It already made me think about whether better brake ducts for cooling might be a modification to make on the car.
2017 ZL1 (on order)
Old 08-16-2010, 10:11 PM   #9
JusticePete
VIR Specialist
Brake ducts are critical on a car as powerful and heavy as a Camaro. As for the pins, the guys that run SCCA T2 and T1 are doing the samething you are doing weekend after weekend. I'ld suggest you get new pins and spring clips avera so often. That should handle the pin problem.
How often do you change out brake fluid?
Old 08-17-2010, 11:50 AM   #10
Chris_B
Chris_B's Avatar
Drives: Several
What size wheels are you running? Soon, there will be a new AP Racing system that will even fit 18" track wheels. This solution will resolve just about any issue people will experience when tracking their Camaro. The front 2-piece rotor assembly utilizes the patented strap-drive technology, currently the best method of attaching an iron rotor to an aluminum hat. It has all the benefits of a full-floating system without the drawbacks.
The brake bias will be set up for optimum braking performance, with special attention given to trail braking, without upsetting the ABS. And, beyond mechanical balance, the system will be balanced thermally as well. This means that the rear brakes will be sized to thermally compliment the fronts (just like is done for top-level pro race cars), not run at different temperature profiles. Drivers have found this approach works very well to help getting pad selection dialed in. It is very difficult to chase pad compounds when you continue to 'fall off the curve' of the rear pads.
All I would suggest adding after that would be cooling ducts with some adjustability to keep the whichever pads you choose in their 'sweet spot'. Then, you will have a system that will last for years with only pad selection to consider from track to track as far as tuning is concerned.
Chris
Chris_B is offline   Reply With Quote
Old 08-17-2010, 07:04 PM   #11
KNS Brakes
Drives: Z06
It's more likely you are outdriving the HP+ pads on track now. Once overheated they struggle to maintain a good transfer layer and thus the pulsing you are observing.
As your front pad is shared with STi's , EVO's and a host of other Brembo equipped cars you have a myriad of pad compounds to choose from. The rear pad is an older Brembo shape which also has good coverage.
Chris_B? Now I know where you work!
KNS Brakes is offline   Reply With Quote
Old 08-17-2010, 08:00 PM   #12
Chris_B
Chris_B's Avatar
Drives: Several
Hi Ken,
Good. I've found at least one person that is convinced that I actually work.....
Chris Bernal
STILLEN Performance Brake Division
AP Racing, DBA and STILLEN Sport Brakes
Old 08-17-2010, 09:23 PM   #13
ericedelman
I've changed the fluid when I've changed the pads/rotors. Maybe I should change it before each track event, instead of every other event?
Chris
I'm using 275/40-20 tires on the factory 9" wheel. I'm still debating wheels/tires. When we take the car to One Lap next year, we need to run a tire from Tire Rack since they sponsor the event. The Michelin Pilot Sport is a good choice, but I'm torn between going to an 18" or a 19" wheel, in part because I may want to go with bigger brakes. I'd be real interested in hearing about the new AP brakes.
2017 ZL1 (on order)
Old 08-17-2010, 09:47 PM   #14
JusticePete
VIR Specialist
Before you change your routine run another event. You can use heat strips that change color when they reach a certain temp or a pyrometer after a s session to check your rotor and caliper temps. Working from some base line numbers will be a big plus.
TireRack does carry the RE-11 Bridgestone in 305/30/19. They work out well for us in terms of performance and driver feedback. Both of these cars are on the Bridgestones. http://www.camaro5.com/forums/showthread.php?t=100421
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
***STILLEN Camaro5 SS Brake System Upgrade Package*** Team STILLEN Suspension / Chassis / Brakes 20 08-06-2010 11:49 AM
Hawk, DBA & Goodridge Brake Upgrade Packages from JSC Speed JSC Speed Suspension / Chassis / Brakes 4 08-05-2010 03:29 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 01:08 PM
***STILLEN Camaro SS Brake System Upgrade Package*** Team STILLEN Suspension / Brakes / Chassis 14 03-16-2010 02:00 PM
