BORLA
Old 08-17-2010, 10:29 AM   #1
reason
reason's Avatar
Drives: 2010 Camaro 2SS / RS
Angry Car wont start-
Just went out to start my car and nothing. Starter doesn't even try to turn the engine over. All i get is a clicking sound under my drivers side dash. No security light or anything.
Tested the battery and its good, tried the spare key to no avail, and even disconnected the battery for 10 min and reconnected and still not getting anything.
Last week or so ive been having problems starting where it would click a few times before she would start. After a few clicks she would turn over no problem.... looks like im getting her towed back to the dealership again.
Anyone else run into similar issues?
reason is offline   Reply With Quote
Old 08-17-2010, 10:33 AM   #2
motorhead
Drives: POS MOPAR
Do you have an early 2010? They had problems with starter wire rubbing through and also the control wire connection down at the start can come loose.
Old 08-17-2010, 10:42 AM   #3
Silver Ice
Silver Ice's Avatar
Drives: 2010 Camaro 2ss-rs
Yup sounds like something going on with the starter
Silver Ice is offline   Reply With Quote
Old 08-17-2010, 10:52 AM   #4
reason
reason's Avatar
Yup - early 2010 - Sounds like thats the problem-
Few weeks ago got nailed with the sticky oil bypass valve as well...
Old 08-17-2010, 10:59 AM   #5
motorhead
Drives: POS MOPAR
If that is the problem there was a recall issued for it a long time ago that you should of received.
Old 08-19-2010, 12:42 PM   #6
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
+1 with the starter.
HeavyD is offline   Reply With Quote
Old 08-19-2010, 12:47 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
if your VIN is higher then 5000, You have a bad battery that's all, Try jumping it to get it to the dealer.
Old 08-19-2010, 01:01 PM   #8
reason
reason's Avatar
well bad news...
so its at the dealership and they were able to get her started. Bad news, i have no oil pressure and lot of noise from the lifters. So they gave up on trying to fix the starter to focus on the oil pressure problem, which they've yet to figure out what's causing. I had the oil bypass valve problem fixed a few weeks earlier and apparently it has nothing to do with it.
GM Technician: " its a good thing you haven't done touched the computer and tuned the car with all the modifications you've done... else your warranty would be void ... and its looking like we may need to replace the engine..."
Me: " yeahhhh.... uhmmm that is good." (fingers crossed they somehow haven't noticed the vector motorsports tune...)
Im assuming they already scanned the computer and for some reason it didn't show... even though i never restored it to the factory tune.... fingers crossed.
Old 08-19-2010, 01:22 PM   #9
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Busted you just posted here and GM reads this site.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-19-2010, 02:31 PM   #10
reason
reason's Avatar
ha thats the least of worries-
they have the car with the computer in it - im not concerned about them reading on the site
Old 08-19-2010, 04:32 PM   #11
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
before they can replace the engine,, they will be asked by gm to connect to your car with their laptop and gm gds software,, the dealer will need to get the cal verification numbers from your ecm, gm then matches their cal numbers on file with the ones they get from your ecm, and if you have a tune they will not match and that is as far as gm will go. warranty void!
this is the standard procedure with "the new gm", and the cal verification numbers are needed for any engine / trans, driveline issues
Old 08-19-2010, 04:55 PM   #12
1badtie
1badtie's Avatar
Drives: 2010 Camaro 2SS RS
dang keep us posted
1badtie is offline   Reply With Quote
Old 08-19-2010, 05:45 PM   #13
reason
reason's Avatar
exactly-
pay to play - we'll see what happens- will keep you guys updated-
Old 09-03-2010, 07:15 PM   #14
reason
reason's Avatar
well - it took nearly 3 weeks but finally got the car back-
Really impressed with GM and their warranty dept. as well as the dealership-
Even with my modifications and the tune they still honored the warranty.
Turned out the oil pump itself was the cause of the oil pressure problems and after replacing the bypass valve and the pump- they went through and tore down the engine and replaced anything with any signs of wear on it.
Anyway- long story short- car is back- running great - and despite the modifications, they covered everything including a rental for the 3 weeks under warranty. ha... now ive got 3 weeks of car parts ive been buying stockpiled in the garage to put on this weekend
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 120 07-31-2016 06:37 PM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
Just for fun take a walk down memory lane Beandip2811 General Automotive + Other Cars Discussion 15 08-09-2009 10:26 AM
#4768 - Delivered and Made Ready the Right Way! Number_9 5th Gen Camaro SS LS LT General Discussions 62 07-16-2009 03:42 AM
What makes a car a "tuner" car? Dentyneice General Automotive + Other Cars Discussion 8 05-11-2009 11:19 PM
