Old 08-17-2010, 05:19 PM   #1
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
2010 Camaro engine problems
I'am new to this forum, i'am just wanting some feedback from other 2010 Camaro's owners, has anyone had any engine problems on the LS3, oil leaking, or other issues, my 1ss (5,585 mi) had oil leaking around the timing cover, the dealer did take of it, but today 2000 mi later i noticed it was a 1/2 quart low on oil, the diy said " low oil pressure" "shut down engine" so i had it towed back to the dealer, and they can't look at it untill next Monday, anyone else out there has had this problem? :(
1954 Belair-man is offline   Reply With Quote
Old 08-17-2010, 05:22 PM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
Low oil pressure could be the oil pump. There's a TSB for it. Not sure about the low oil though.
Eric Baker is offline   Reply With Quote
Old 08-17-2010, 05:26 PM   #3
AMPM1678
AMPM95
Drives: 2010 RY Camaro 2SS/RS LS3
haven't had this problem with mine may have to check the oil pump out
AMPM1678 is offline   Reply With Quote
Old 08-17-2010, 05:27 PM   #4
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
i noticed some drippage under my L99 after parking it for a week. the dealer found a leak at the oil cooler, and a leak between the engine and oil pan.
KeepItGreasey is offline   Reply With Quote
Old 08-17-2010, 06:05 PM   #5
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
I had a leaky oil cooler adaptor gasket which the dealership fixed. There is a TSB for it as well as a TSB for a faulty oil pump check valve. I read other threads about the oil pump problem so it's a known problem.
Not a Camaro but it works for now!
Old 08-17-2010, 06:55 PM   #6
ffrcobra_65
there is also a TSB on the Rear Engine Cover oil leak due to porosity issue.
Old 08-17-2010, 09:26 PM   #7
Gangster
Camaro Crazy
Gangster's Avatar
Drives: 2010 1SS/RS IBM/Grey M6
when i got mine new for the first few days i smelled the odor of fresh oil burning on the exhaust. I gave it a few days to go away and sure enough it did.Thank god,I thought it was gonna be something major cause thats the kind of luck i have.
Gangster is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
Lingenfelter 2010 Camaro Engine Packages - up to 800hp! Sizzox 5th Gen Camaro SS LS LT General Discussions 108 04-14-2010 07:09 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
