Old 08-17-2010, 08:49 PM   #1
spacecowby
spacecowby's Avatar
Drives: 2010 black 2SS/RS
3.73 for manual?
So I am thinking about getting gears for my car and I mentioned 4.10 to my tuner/mechanic and he said to go with 3.73. He said 4.10 would be to much. From what I've read on here 4.10 is the way to go for manual, just wanted your input.
Black cars are not hobbies, they are an obsession
spacecowby is offline   Reply With Quote
Old 08-17-2010, 09:39 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
4.10 is not too much. At 70-75 mph you will be running just a tick under 2000 rpm in a M6 equipped Camaro and you will realize an equivalent gain of approximately 20% or 84 rear wheel lb.-ft. of torque. We have had several customers go even further to 4.33s.
If you have any questions feel free to hit me up.
Old 08-17-2010, 10:55 PM   #3
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Drives: Mikes Hard Lemons
Let me know if you decide to sell your stock gears.
CAMAR0 is offline   Reply With Quote
Old 08-17-2010, 11:36 PM   #4
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Go with the 4.10's, you will be happy. I think I saw you in another post, you have a cam don't you? If so and you plan to stay NA, the 4.10's are what you need.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 08-18-2010, 11:54 AM   #5
spacecowby
spacecowby's Avatar
Yes I have a 229/236 cam and plan to stay NA. 4.10 is the way to go.
Old 08-18-2010, 12:21 PM   #6
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
That's a great question! Thanks for asking it, now here is a follow up question for the tech guys.
If you put 4.10's in, do you need to upgrade the axles and the drive shaft at all? With the added torque it would seem to put more stress on the stock parts.
armysig is offline   Reply With Quote
Old 08-18-2010, 12:22 PM   #7
usmcjlp
Drives: 2SS/RS LS3 RJT
I am installing a supercharger in conjunction with the LS9 cam and headers. Someone has recommended the 3.73 gears to me. Do you think it will work well? Should I go with 4.10 or stay stock?
My goal is mid 600s at the wheels, for now. Eventually, I intend to build the motor and up the boost.
usmcjlp is offline   Reply With Quote
Old 08-18-2010, 01:10 PM   #8
Apex Motorsports
For a Camaro that puts more than 600hp to the wheels I usually recommend 3.73.
Old 08-18-2010, 01:14 PM   #9
Apex Motorsports
It depends on what else you have done and how you use your car. You might consider upgrading the axles if you are making substantially more power than stock but you can always just hold on to you money until they snap.
Old 08-18-2010, 01:23 PM   #10
usmcjlp
Thank you. I have heard that the gears really wake the car up. I tend to drive agressively and both 5th and 6th gear seem too tall for my driving habits.
Old 08-18-2010, 01:36 PM   #11
Mcnamee
Mcnamee's Avatar
Drives: 2010 Camaro Synergy & '87 Monte SS
are there any 3.73's for the v6 or higher?
Synergy Green Camaro: Global MANUAL total:465 and NON US manual total :62, and I have 1 of 62 non us
Mcnamee is offline   Reply With Quote
Old 08-18-2010, 01:40 PM   #12
Apex Motorsports
They really do. The problem once you start getting into higher power levels is traction and breaking parts. You can go to the 4.10 but you really need to have all of your supporting modifications in place. No corner cutting.
Old 08-18-2010, 01:47 PM   #13
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
4.10's FTW!
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 08-18-2010, 08:40 PM   #14
Apex Motorsports
Originally Posted by POWERFREAK View Post
4.10's FTW!
3.73 Gear? jo0oker V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 27 08-11-2014 12:16 PM
Any 1/4 mile times with l99 3.73 gear swap only? 73duster V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 08-05-2010 08:36 PM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 09:16 AM
I got my 3.73 Gears installed today!! Camaro21 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 33 07-15-2010 05:47 PM
3.73 vs 4.10 gears sexystreetmachine V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 06-15-2010 10:09 PM
